-   -   induction cooktop range (http://forums.pelicanparts.com/off-topic-discussions/865571-induction-cooktop-range.html)
sammyg2 05-16-2015 12:38 PM
I was at pacific sales today buying a toto ter-let, and I was checking out the induction cook tops.
They had a couple that were really nice and priced pretty darned low and it got me thinking.
Then I did some research, those bastages suck the power big time!
220v, up to 7200 watts. that's a bunch-O'amps
Now i'd never use all 4 or 5 burners at once, but still.
I have natural gas now and the cost to run a 220 service just for a cook top is a deal killer. bummer, I was all excited and it burst my bubble.
campbellcj 05-16-2015 04:53 PM
They look clean and high-tech but for actual cooking, gas rules.
biosurfer1 05-16-2015 05:15 PM
7.2kW? That's insane. I'm not sure the rest of my house would hit that peak with everything on! Good thing there aren't residential demand charges in most places.
DanielDudley 05-17-2015 09:38 AM
That would be a 30 amp breaker. Electric ranges with an oven often run 50 amps.
I like gas, but induction cook tops might be good with little children around.
908/930 05-17-2015 10:10 AM
They do require a large power source up to 45 amps, but more efficient then other cooktops, almost all the energy goes to heating the pan, depending on your price of gas also less expensive to run and as good heating control.
They do require pots and pans that have a base that is magnetic to work, but lots of them are anyways.
1990C4S 05-17-2015 10:13 AM
I can't imagine the cost of cooking ever being a serious concern. There are about twenty other factors I would consider before energy cost.
ckissick 05-17-2015 10:15 AM
I have an induction stove and love it. It does not require 220V. While overall wattage is higher, it's efficiency more than makes up for it. Induction is the most efficient form of heating.
I did a little research and found this: "A 2000-watt electric stove uses 320 watt-hours to boil 2 liters of water in 9 minutes 50 seconds. The same job takes a gas range 8 minutes 18 seconds and requires 3100 watt-hours (converted from Btu). A 2800-watt induction unit boils 2 liters in 4 minutes 46 seconds, using 225 watt-hours."
It's very easy to clean. I like gas stoves, but they are a pain to clean. What I like best about induction is it's instant heat control and ease of use once you learn the settings.
Rinty 05-17-2015 10:27 AM
We've had induction for about five years, and continue to be impressed with it. I think it's one of the best kitchen upgrades you can do.
As mentioned, they are very energy efficient.
911_Dude 05-17-2015 02:24 PM
Gas is the only serious way to cook.
mjohnson 05-17-2015 09:00 PM
Yah, nobody out there is using crazy-not-gas
The high-tech tools of Keller's kitchens - CNET
Of course, maybe he's just some hack...
dentist90 05-17-2015 09:17 PM
We have a gas cook top and the heat is instant, but you just know a lot of the energy is lost when the handle of your pots is too hot to touch and you burn the hair off your arm reaching for the back burner. I imagine the initial cost of induction is quite a bit higher but the technology is amazing. Take the pot away and the surface is cool(ish).
JavaBrewer 05-17-2015 09:38 PM
Haha. Gas Cook top is the A game.
crustychief 05-17-2015 09:52 PM
I honestly can't recall hearing the phrase " now you're cooking with electricity!". I am currently remodeling the kitchen and upgrading to a gas cook top.
greglepore 05-18-2015 05:32 AM
A lot of good home cooks use an induction "hot plate" for specific tasks like bringing a large pot of water to a fast boil. A cheap compromise if you already have a nice gas cooktop.
I'd seriously consider induction if I were to do it over.
Peterfrans 05-18-2015 06:00 AM
We have an induction cooktop (a 10.8kW Siemens). Very pleased with it, heat is easy to adjust and cleaning is a breeze. Gas tops look better (imho) and probably offer more flexibility (like a wok burner) but for day to day use I think a induction top is superior.
