^ I understand the concept that the systems work together, etc.
But what do you mean by "tune" in terms of a performance upgrade? That seems like just normal maintenance. I also have to say, as a lifelong aircooled guy, I'm not comfortable calling snap in plastic parts anything other than a cosmetic modification. |
It's the equivalent of ''chipping'' your 911 and converting your MAF |
That sounds good. I think I saw something about using the TB and Plenum from a Spyder on a site the other day too. Same idea as the GT3 TB and plenum mod that you did, but slightly different parts. Yeah, I'd be happy to do the performance upgrades too, but I'm still under CPO warranty for a bit and not looking to spend that much right now. I'd also really love a torque biasing diff. If only I had a bunch of extra money just laying around. |
Rusnak, sorry -- I should have been more clear; I'm used to posting about mods over at Planet9, where all of the users already have Boxsters or Caymans and are used to the vernacular. Yes, by TB I mean "throttle body" -- the opening for the IPD plenum is 82mm, larger than the stock 987 opening. It is designed to work with a 997 GT3 throttle body. And the "tune" is exactly what the others describe -- it's like "chipping" a 1980s-90s car, or putting more aggressive jets/carbs on an older car. Bolt-on mods alone won't significantly improve the performance of a 987 because the car's computer will always deliver the same air-fuel mixture as long as the software remains stock. You might get a little bit more throttle response out of bolt-on mods, but to optimize their impact, you need an ECU tune. Since everything is managed by an onboard computer these days, when you purchase a "tune," the company sends you an OBD port adapter and software. You load the software up to your laptop and connect it to your car's OBD port. The program then reads the file from your stock computer, which you send to the tuning company with a list of your bolt-on mods. The tuner then builds a "map" in the software that takes into account your mods and optimizes the air-fuel mixture, timing, etc., to get more performance out of the car. You then reconnect your laptop to the car, upload the new software map, and bingo! You get a much smoother and stronger torque curve as well as considerably higher peak HP. It really does make a pretty huge difference. |
I've been looking at this Porsche Diagnostic Store | Durametric Software Products for Sale It's to read trouble codes and reset the service light. What do you guys use for that? |
The one cosmetic mod (actually 2) that I did was to switch all of the interior lights and exterior halogens to LED. Now the lights are all LED and whatever the headlights are. They look like there might be two different types of lights in there. I'd love to switch them for HID but I need to find someone who's done that.
My recommendation is to kill two birds with one stone. I went with VividRacing, which Pelican member Sydney (porsche4life) works for; I'm sure he'd be happy to answer any more specific questions you might have about their products. They have awesome customer service, in my experience, and I am very happy with the tune. |
Love Durametric- couldn't imagine owning a newer Porsche without it.
Because they're ugly...
I think I need to get a PC laptop to go with it. I have an OBD II scanner, but it's limited in terms of what it can read. OTOH, the scanner cost more than the Durametric does. |
Lots of good comments on this thread.
We have a 2003 2.7 Boxster as a loaner car and are building a 2002 3.2S race car. The 2.7 car is fun to drive. Most 996/997 owners who use it say "can't believe how fun it is" or "Its quicker than I expected". They are fun cars, but not for everyone. Interesting too about the gender issues. I prefer our 997 S and 996 Turbo. My wife prefers our Cayman (soon to have a built 3.8). But we both enjoy driving the Boxster with the roof down. |
Are all these reading capabilities available on the "Enthusiast Kit"? Pricing actually isn't too bad. |
Matt hit it perfectly. Our cable will read the standard codes, durametric is way more in depth for troubleshooting.
And yes if you are interested in ECU tuning, pm me! |
How long does it take to do and undo the desnorkel mod? It looks like it's about 10-15 mins if that unless you are going to put a mesh in place. Of course, with the Spyder vent insert, I wouldn't think the mesh would be necessary. OK, I've also looked at a couple of explanations of the desnorkel process, and it seems there is a huge restrictor plate that is designed to prevent item intrusion (ie cigarette butts) and an actual snorkel. Is the goal to actually desnorkel or deplate? I would think the snorkel would be good, but the plate would be bad. |
Mods that I'd like to do are TB and plenum with a tune, and torque biasing diff. I find that at times I get some wheel spin that I don't like. On my previous car, a factory turbo miata, I had a torque biasing diff, and I liked what seemed like a bit more predictable traction and predictable behavior with it. At least now that we are in the summer months, I have more traction than when it's cold out. I factory short shift kit might be nice too. The Spyder vents would also be something that I'd consider as well as some 18" wheels if they were lighter than my 19". |
| All times are GMT -8. The time now is 04:37 PM. |
