Model Citizen
herr_oberst's Avatar
Cutting MC (armored) romex
Hey there Pelicanites.
I'm doing a little repair on the garbage disposal and I need to shorten a length of armored romex. Is there a good (safe) way to go about doing this without a special cutter like the pros use?
Thanks, for any advice!
Old 07-17-2015, 08:16 AM
356racing's Avatar
Just fold(bend) it over at the point you want to cut. The tight fold will pull it apart and then a couple of nips at the outer shell with some side cutters and you are done.
Old 07-17-2015, 08:36 AM
Model Citizen
That's great!
Thanks a lot. I have enough to do this job and no more so I didn't want to make a mistake and have to buy a lot more than I would ever need!
Old 07-17-2015, 08:41 AM
Serial Lurker
ledhedsymbols's Avatar
Send a message via AIM to ledhedsymbols
Make sure you use anti-shorts, I throw a wrap of tape around it to keep it in place.
Does anyone know where the love of god goes when the waves turn the minutes to hours?
Old 07-17-2015, 09:14 AM
non-whiner
mreid's Avatar
^This!
You do not want the shield rubbing through the hot lead and the disposal makes enough vibration to do it quickly!
"Too much is just enough."
Old 07-17-2015, 09:17 AM
Model Citizen
Thanks! Good advice, and the PO didn't use them...
Old 07-17-2015, 09:19 AM
Serial Lurker
Homeowner special...
Old 07-17-2015, 09:21 AM
Model Citizen
That's why I ask the experts on Pelican!
Old 07-17-2015, 09:36 AM
Platinum Member
dad911's Avatar
I usually cut the bump/rib with a hacksaw, not going all the way through, then snap it off. Cut is perpendicular to rib:
Old 07-17-2015, 10:19 AM
least common denominator
scottmandue's Avatar
This is what I used to do when installing weather tight romex... bend a little... cut with hacksaw... bend a little more.. finish with tin snips (I suppose diagonals will work too)
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 07-17-2015, 10:26 AM
DanielDudley's Avatar
I have one of these but it is not a Klein. I do a lot of cable though.
Klein Tools BX and Armored Cable Cutter-53725 - The Home Depot
Old 07-17-2015, 02:00 PM
Use a pair of Klein pliers.
Piece of cake.
+1 on the bushing. No need for tape on it.
Use connectors with the two set screws, the ones that look like Romex connectors. All others are junk>
Carter
Old 07-23-2015, 08:14 AM
Real BX connectors hold the bushing, and have a little slot for the tab.
Old 07-25-2015, 03:40 PM
wdfifteen's Avatar
+1 on using proper bx connectors. The redheads just fall out if you don't.
Old 07-25-2015, 05:18 PM
