-   -   Miata rough idle in drive smooth idle in neutral? (http://forums.pelicanparts.com/off-topic-discussions/877717-miata-rough-idle-drive-smooth-idle-neutral.html)
scottmandue 08-06-2015 02:14 PM
Originally Posted by NotaBRG (Post 8742421)
Another thought is that your tranny fluid needs to be replaced and is causing a lot of drag in gear vs neutral. Just a thought, I don't really know.
Had trans fluid changed at dealership, just to be sure I checked the fluid per owners manual (warm/engine running) and it looks clean and level is good. I'm also leaning toward suspecting the trans. I've refreshed the engine, new belts, all new cooling system, new plugs/wires, etc.
I need to look up the model of trans and see what I can find about it.
rusnak 08-06-2015 04:05 PM
This chick would like to speak with you about your Miata w automatic trans:
http://forums.pelicanparts.com/uploa...1438902350.jpg
