And UI is solving it: Note that Underwriters Laboratories (UL) will require ALL GFCIs to be self-testing beginning in mid-2015. Self-Test GFCIs perform a periodic internal self-test to confirm that protected power is available. Ian |
Who the hell tests their outlets monthly? That's a defective product, in my view.
In my own house, I have taken out all GFIs in my garage and no AFCIs, problem solved. I think I will live just fine. |
maybe rodents chewing through the buried cord and providing the leakage. Has happened on my low voltage buried lighting distribution
Second day.
The pump continues to work with the new grounded plug. No tripped breakers. Has had plenty of time to build condensation in the submerged pump housing if that were the problem. So, it seems that moisture had worked it's way into the molded power cord/plug. Not a lot, but enough to trip the GFCI breaker. So, cost me $45 for a replacement GFCI breaker (which I didn't need, but can't return). And a new plug, $6. But a Whole Lot Better than $500+ to replace the pump. Thanks for the suggestions! |
Great! Shows it pays off to be persistent when trying to solve problems. The moisture problem is what caused a buried chord I had for an outside light to short. I think I forgot to mention that initially.
| All times are GMT -8. The time now is 03:32 PM. |
