-   -   Rear engine vs. mid engine ? Cayman vs. 911. (http://forums.pelicanparts.com/off-topic-discussions/884726-rear-engine-vs-mid-engine-cayman-vs-911-a.html)
sugarwood 09-27-2015 07:40 AM
I came across this article.
10 Ways the 2014 Porsche Cayman Is Better Than the 911
What is this polar moment they are discussing?
What is this commenter talking about?
Say what you will about the Cayman's polar-moment-of-inertia advantage over the 911, but the fact remains tail force is where it's at in practical road course and GT driving. Just look at that big rear wing on a F1 car. It only opens/relaxes mid way on a long straight. Otherwise, it's tail-down force the rest of the way around the circuit (and that includes Monaco). This is what makes the 911 worth the extra money, truly effectively-balanced driving performance. Otherwise, Porsche would not build the 911, iconic looks, backseat and sunroof aside. They had it right in 1949, and haven't changed the core model's weight distribution layout since. The laws of physics never change.
Any truth to this comment about sliding in a mid engined car, and supposedly not being able to recover from it, since there is to weight imbalance?
Can someone review why rear engine is ideal for braking?
911 is one of the best performance cars in the word for a reason. Vic Elford in his book "Porsche High-Performance Driving Handbook" explains it best. In short, 911 has best weight distribution for acceleration (even out of the corner) and best weight distribution for braking. On 911 tight low speed turns can be taken at higher speed than on a mid engine car. Finally, a light nose allows for a very quick turn in.
If you know how to control overseer (which you should if you buy sports cars to go fast, not to show off) 911 is actually safer than a mid engine car. A mid engine car will start loosing cornering traction evenly, which means that if it started to slide, it will continue sliding until enough energy is lost. This behavior is ok, if you have enough room to slide to the outside of the turn on a wide race track. But what if it happens on a tight mountain road? 911 in the same situation will start over-steering (i.e. it will actually start turning even tighter) which can be controlled by a driver of a reasonable skill level without using any more room on the road than was originally planned.
Also, while 911 is indeed more likely to start over-steering than a mid-engine car, 911 over-steer is more predictable. The same low polar moment that allow a mid engine car to feel so nimble, can potentially cause difficult to predict snap over-steer if you lift off too abruptly or drive over a patch of wet pavement.
J P Stein 09-27-2015 07:57 AM
They'll get no argument from me.
Out there on the edge, the mid engine does its best work.
The rear engine does give a better warning of dropping off the cliff, but the edge is farther away with the mid motor.
My old 914 would gobble up any species of 911 (GT2,GT3, what ever). at autocross.
Tobra 09-27-2015 10:10 AM
Nothing drives like a mid engine car. F1 cars do not have the same layout as a 914/Cayman by mistake
Braking and acceleration in rear engine are good because of weight transfer and traction of weight on drive wheels. As far as polar moment. Imagine an iron bar with the weight evenly distributed. Now image a pipe, with weight at the ends, that weighs the same as the bar and is the same length. Which do you think would be easier to make spin?
LeeH 09-27-2015 10:17 AM
I always think of a 15 pound bar that's 3' long vs a 15 pound bowling ball.
Grab the bar in the middle and see how fast you can rotate it back and forth. Now do the same with the bowling ball.
LEAKYSEALS951 09-27-2015 10:26 AM
polar moment of inertia (as I understand it) refers to the distribution of the mass in an object. For example, in an old corvette- the weight is in the front from the engine. In an old 911, the weight is in the back. These are high polar examples. A mid engine car has the majority of it's mass in the center, so it is not a high polar object.
I think it was a 1980's panorama article that described this and used a thrown dart as an example- with the front of the dart (the weight) having the most mass(and inertia), and the feathers in the back- so the mass continues to fly forward as the feathers provide drag- keeping the dart flying straight.
A 911 is like a dart thrown backwards, which gives it it's unique handling characteristics.
Having the engine in the middle theoretically keeps the moment of inertia equally distributed between front and rear- giving the car a potential advantage in neutral handling.
Thats my story and Im sticking to it.
masraum 09-27-2015 10:32 AM
http://forums.pelicanparts.com/off-topic-discussions/737448-polar-moment-inertia.html
This is a good thread with pictures and explanations.
dennis in se pa 09-27-2015 02:06 PM
Yes.
911 people (I have had 3) will tell you that layout is better. But the engineers know mid engined layouts are better. That is why the most expensive race cars in the world have mid engines. The 917 was mid engined.
I also had a Boxster. That was easy to corner with. In the 911 you had to have a lot of experience to really play with it.
masraum 09-27-2015 03:03 PM
911s are great at getting around a race course and tons of fun, but I believe that the ultimate way to get from corner to corner and through the corners is a mid-rear car. With a mid-rear, you've got the low polar moment from the weight being in the middle, but you've also got a slight rearward weight bias that gives better traction.
It's all about Physics.
cockerpunk 09-27-2015 03:28 PM
the only reason the 911 has a rear engine is to fit the rear seats.
its no coincidence that all porsche hyper cars have been mid engined, and all racers besides the 911 series have been mid enigned.
that all being said, in the right hands, rear engined does seem as capable as mid engined. i think its trickier to drive them well though.
wdfifteen 09-27-2015 08:16 PM
Bingo. It's about balance between a low polar moment and having enough weight on the rear wheels to aid traction for acceleration. The big Can Am cars of the early 70s had rear weight bias with could be adjusted because the engine was between the wheelbase.
Has there ever been a race car with mass that can be moved while under way?
onewhippedpuppy 09-28-2015 04:34 AM
Think of a low polar moment of inertia as the resistance to changing direction, because mid-engined cars tend to be very responsive to inputs. To me that's the biggest different between a Boxster/Cayman and a 911, the mid-engined twins are instantly responsive.
Nostril Cheese 09-28-2015 04:59 AM
I've had the opportunity to drive my buddy's Cayman R. Pretty hard to want a modern 911 after driving it, excluding a GT3 or something.
David 09-28-2015 06:44 AM
All I can say is I've taken corners on the street at stupid speeds in my Cayman with little more than the tail stepping out a few inches or the fronts scrubbing a little. I can't say the same for my old 997.
javadog 09-28-2015 07:58 AM
There's a fair amount of BS in that article, and a definite bias from the author, so digest it with a little salt. Or quit reading that website, which is more or less worthless anyway.
There was a test done a while back (can't remember who did it) that set out to compare a 911 and a Cayman, without a power difference being the deciding factor. In the end, the 911 proved to be the faster car around a track. That wasn't a test of what's theoretically possible, just a real-world result based on how the cars were delivered from Porsche, which is what matters for most people, since most buyers don't change their cars much. Each car had advantages and disadvantages compared to the other, but the 911 proved to be the better tool around an entire lap.
There are big differences between the two cars ( I happen to find the Boxster the most fun to toss around) but don't assume the mid-engined cars have the most mass right in the center. They don't: it's still towards the rear, just not as far rearward as a 911. Yes, they might turn in a little more crisply, but I don't know of anyone that *****es that a 911 won't turn into a corner well. They spin a little more easily, so you need to be a little quicker to catch one. Given the electronics they have now, nobody should get that out of shape, anyway.
A 914 is a different beast altogether. Lots of fun, but tricky at the limit. Their autocross prowess has as much to do with their huge weight advantage over just about any car, as it does where the motor is placed.
The backwards arrow analogy wasn't related to the polar moment of inertia of a 911, but to the fact that its center of mass was behind its center of aerodynamic pressure, which is what makes it so unpleasant in cross winds. That's another issue, altogether...
If you look at F1 cars, or other racing cars, you can usually find that they do not have a 50:50 weight distribution. That's not an optimum distribution for a rear wheel drive car. It's not all that unusual to see a bias that approaches 70% on the rear, depending on the intended use for the car.
JR
onewhippedpuppy 09-28-2015 10:14 AM
I didn't even bother with the article, my comment was in general comparing a Boxster/Cayman with a 911. If you are looking for Porsche buying advice from Edmunds, you're already too far gone for help. Calling one of them better, unless you care about lap times, is totally subjective. They each have their own unique charm, but it is a much different driving experience. Personally I find the Boxster to be the most pure fun of any modern Porsche, it has a lightweight and tossable feel that even the Cayman can't match. It is also the slowest around a track, back to that whole not caring about numbers thing.....
Captain Ahab Jr 09-28-2015 11:48 AM
Mercedes in DTM in the 90's used it, slabs of metal on a moveable sled
Retrospective>> Awd Tourenwagen Meisterschaft - Speedhunters
Also in F1 but with mercury moveable ballast system, it never got as far as asking the FIA for permission as internally within the team it was deemed to be just too much of a health risk
javadog 09-28-2015 12:14 PM
It's interesting to note that F1 has evolved towards a fairly conservative f/r weight distribution of around 46/54, give or take a percent or so. Note that you have more freedom to play with the distribution if you don't care to be at the minimum wieght limit, since the rules specify a minimum weight for each axle, but that's like asking a supermodel to eat pizza before a major shoot. Ain't going to happen....
cockerpunk 09-28-2015 12:30 PM
reducing weight is always more important that the distribution of that weight.
javadog 09-28-2015 12:32 PM
Maybe. Read up on Porsche's bergspyders from 1968, or so.
JR
racer 09-28-2015 02:18 PM
Having moved from a 914 to a 911, I will share this (and imagine others have observed the same).
A 914 will let go, often with little notice when it appears at its limits. It can require constant attention to keep it balanced and not spin (and spin and spin).
The 911 always lets you know the weight it back there. The key is learning how to use its weight to an advantage (ie, like Vic Elford quoted above says - use the weight o help the car turn for you. Anticipate the slide and control it). You lift, you rotate, you plant, you steer a little bit.
I had hoped my Boxster would be like the 914.. it wasn't. It understeered and lifting never rotated the car, just slowed it down.
Now, was that safe? sure, and in an era of frivolous lawsuits, it keeps Porsche in business.
Are mid-engined best? overall, yes but most really good mid-engine race cars are actually 46-54 or so on the front/rear for traction (handling) reasons.
Bill Verburg 09-28-2015 02:23 PM
low polar moment just means the car can be rotated w/ less force than a car w/ higher polar moment because the weight is more toward the center of rotation.
A commonly seen example of changing polar moment is an ice skater spinning, when the arms are pulled in you can see the rate of rotation increase noticeably, when the arms are extended the rate of rotation slows noticeably. This is because the total energy or rotation is conserved during the transition from one geometry to another.
In a car polar moment is more or less fixed, it does decrease a bit due to gas usage
Cayman has lower polar moment than 911.
Sometimes it's better to have a higher polar moment, on acceleration and deceleration are 2 prime examples.
Another point is that the inputs don't have to be so finely controlled w/ a higher polar moment, A 911s tail will always let you clearly know what it wants to do and responds to drivers input well, you want to rotate more? OK, let off the gas, the car will rotate more. You want to stop rotation? OK, gas it it, the rear plants and the car squirts ahead. You do have to steer a bit while all this is going on. In a Cayman you will want to be more subtle and not have to counter steer as much.
Someone mentioned that you can lower the polar moment of a 911 easily, this is true, a 911 w/ f/g or c/f bumpers as opposed to the stock rugged bashers will have a lower polar moment and will rotate more easily, If you have a chance to back to back drive the difference is amazing.
stealthn 09-28-2015 06:43 PM
After getting used to the Cayman it is a completely different drive than my old SC. The 911 can rotate on a dime, sometimes whem you don't want it to :) but it can shoot out of corners like no tommorrow. The Cayman feels like it's on rails around a corner with no real feel of a rear break away, but a re-correct after the corner that takes a second before you can apply the power properly. Both understear but I managed to tune most of it out of the 911, I haven't had the chance to do it on the Cayman yet.
Both are completely fun cars to drive, just very different.
masraum 09-28-2015 07:28 PM
911, weight in the rear. The front of a 911, because there's not much mass/weight, is very easy to get to change direction. IE, you turn the steering wheel a little and the front end goes where you point it like it's telepathic. The rear end because it has all of the weight, wants to keep going in a straight line and takes a lot more force to get it to turn (hence the bigger rear tires). On a spirited drive, you can get that to work for you. A 911 can be a formidable car in the right hands.
A mid engined car (in this case, mid-rear), with the weight mostly in the middle (but as stated, still usually with a rearward bias, is still going to be pretty good at turning because of the low front weight, and since the weight is more centered, the rear is also a little happier to rotate for you. Because of that, a mid engined car is usually better at changing directions than cars that aren't mid-engined. But, a car that's happy to change directions (ie, spin faster) can also require very quick reflexes to catch when it does spin.
A balanced car that's forgiving and easier to drive is a car that's balanced, but has a high polar moment, think 944 with the motor in the front and the transmission and differential in the back, same as the newer corvettes. I could swear that there's an article out there where Derek Bell says that the 944 is better than the 911 because of it's balance and since the weight is divided between each end not as quick or likely to spin. I think the gist is that the 944 is very easy and forgiving to drive because it's got a high polar moment.
