-   -   Anyone own a Sub-Zero Frig/freezer? (http://forums.pelicanparts.com/off-topic-discussions/886471-anyone-own-sub-zero-frig-freezer.html)
red-beard 10-10-2015 05:22 AM
I need a picture of the nameplate, showing max current.
TIA!
mreid 10-10-2015 05:41 AM
Mine is installed in the wall. The plate is on the back, so no access. I do have the wiring diagram is that helps.
billybek 10-10-2015 05:58 AM
What size?
Some are dual compressor units. One for the freezer one for the refrigerator.
Most of their refrigerators still use a designated 15 amp circuit/plug.
red-beard 10-10-2015 05:59 AM
Does it show the amp ratings?
red-beard 10-10-2015 06:03 AM
Originally Posted by billybek (Post 8830098)
What size?
Even the dual frig/freezer 40 inch units call for a 15 Amp circuut. I found a picture of the compressor and it shows 5 Amps LRA, which would imply 1 amp running. On most frost free units, the heater is the largest draw.
dad911 10-10-2015 06:07 AM
You can get specs here: Product Specifications and Manuals | Downloads | Sub-Zero & Wolf Appliances
red-beard 10-10-2015 07:04 AM
I've looked at all of the "spec" pages. They only list the capacity of the circuit to be 15 amps. I'm looking for the running amps of the unit.
mreid 10-10-2015 08:08 AM
No luck. I took the schematic out and opened it up. It only says 115v, 60 cycles. Sorry.
island911 10-10-2015 09:00 AM
Yeah the defrost element may draw as much or more than the motor. Maybe around 600W.
You could check Repair Clinic for the part. They often have more info on the individual parts -http://www.repairclinic.com/
look 171 10-10-2015 11:24 AM
Try popping open the grill on top, there's where the tech paper work is usually place when it leaves the factory.
mreid 10-10-2015 11:43 AM
That's where I got the schematic. Only other paperwork is the instructions for the 90 degree door lock and there are no plates on other info, only the water filter.
Eric Coffey 10-10-2015 02:16 PM
Older 48" side-by-side:
http://forums.pelicanparts.com/uploa...1444511779.jpg
red-beard 10-10-2015 03:32 PM
Thanks Eric.
Kraftwerk 10-10-2015 07:56 PM
BTW Make a dedicated line to your fridge. So it has a breaker all to itself ie. nothing else is on that line besides the fridge.
chocolatelab 10-10-2015 08:46 PM
Originally Posted by Eric Coffey (Post 8830688)
Thats a new one, mine says 1988.
Its about to take its final tick.
i don't even want to look for replacement.
