Can I get some help from the military guru's here?
I'm trying to identify the service ribbons my father wore on his uniform. U.S. Army CWO4 Nike Missile Specialist. I've found a couple resources on-line that have helped me identify his "Korean Service" ribbon and his "WW ll Service" ribbon and the "Army Commendation Medal".
I'd appreciate any other resources that you may know of or if you can identify any of the ribbons. Thanks All, |
The pic is upside down but
ARCOM ww/cluster Good conduct, clasp signifies second award WWII Victory Medal Army Occupation Medal National Defense Service Medal Korean Service Medal, the stars signify separate campaigns UN Service. |
Wow, That was fast. Thank You
Another question........ I'm told (my mother) that he was involved in an action in Korea known as the "Double Nickel"? Any way of finding out more about this? |
The only thing I could find digging around quick is referencing the 55th MP Co. Apparently, they processed a lot of POWs.
ETA: If he was with 55th, there should be a second set of ribbons, likely just one or two, with gold braid around the edges. They're unit commendations. http://www.history.army.mil/html/forcestruc/lineages/branches/mp/0055mpco.htm ETA Again: The Nike system went into service in '54, your dad was obviously in well before that as he'd have served before '46 to get the WWII Victory Medal. Do you know what he did before working on the Nike? |
From what I have been told it was an offensive action comprised of segregated troops that suffered heavy casualties but were victorious in the end.
Kevin the ribbon stack is inverted. I have flipped it for you.
http://forums.pelicanparts.com/uploa...1445226911.jpg Hopefully our Army brothers and sisters will correct any errors (I am Navy), but here goes: Top Row: Army Commendation Medal with oak leaf cluster (two awards) (Depending on when awarded this could have been a ribbon or if after 1960 they were full medals) Middle Row Left: Good conduct Medal (with two loops for two awards) Middle Row Middle: World War Two Victory Medal Middle Row Right: Army of Occupation Medal (Which is now retired. Though this ribbon does not indicate which occupation it was awarded for, the Full Size Medal would have the clasp stating which it was) Bottom Row Left: National Defense Medal Bottom Row Middle: Korean Service with Two Campaign Service Stars Bottom Row Right: United Nations Service |
Regarding the Army Commendation Medal, I have one in the original presentation case. It has the full size medal, a ribbon and a lapel pin but it doesn't have the oak leaf clusters on it. That must mean it was the first time he was presented with it? |
Can you help identify some of these for me?
http://forums.pelicanparts.com/uploa...1445227877.jpg |
The one below is 27th Ordnance Maintenance Co. 1st Cavalry. 2nd vertical column from the right is 60th Air Defense Artillery Regiment https://en.wikipedia.org/wiki/60th_Air_Defense_Artillery_Regiment far left column is 3rd Air Defense Artillery https://en.wikipedia.org/wiki/3rd_Air_Defense_Artillery_Regiment (I'm a little iffy on this one, it's the closest match I saw that had Korea Service, they change the crests from time to time) The middle vertical column is 61st Air Defense Artillery https://en.wikipedia.org/wiki/61st_Air_Defense_Artillery_Regiment They were consolidated with 436th 548th and 740th Antiaircraft Artillery Missile Battalion which operated NIKE missiles. |
Thank You.
How do you know all this? I'm thoroughly impressed. |
I have absolutely no idea what the row of Jaguars signify.
I'm from a way different generation than this, but I speak Army and my Google-fu is strong. |
Looks like he was just an artillery guy until the NIKE systems were introduced and jumped at the chance to train on them and make Warrant. |
https://www.archives.gov/st-louis/military-personnel/public/index.html If you catch them on a good day you can get the records inside of a month. Your fathers records may have been affected by the fire in '73, that slows things down a bit. |
| All times are GMT -8. The time now is 11:06 AM. |
