Hissing air hose fittings
Any other skinflints out there?
All my air fittings hiss at me and I think if I could change out that rubber washer in the picture it would stop. The deformed ones I have are about .575 OD .225 ID and about .14 thick. Anyone else replace these? Where would I get something like that?
Rick 88 Cab |
Is it hissing all the time, or only when something is plugged in to it?
Just replace the whole thing. They're not very expensive.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thats what we always do Pete!
Not as cheap as a washer should be and everyone I know, their air fittings hiss if connected. It is pretty simple to unscrew that straight threaded fitting and put in a new washer if you found the right size.
Rick 88 Cab |
What about the rubber piece in these guys? It appears to be custom molded but the Foster website says nothing about it.
Rick 88 Cab |
They're on their web site but I have no idea where to order them from. If it's not a Milton then replace it with one. |
That is a 30 year old (made in USA) Milton coupler.
Rick 88 Cab |
Looks like Tooltopia has that Milton (MILS715) coupling for $3.32 (Might not be USA made?)
Save on Milton S-715 at ToolTopia.com
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Miltons won't leak a little when something is plugged in to them? If so I'm interested...
'87 924S (Sold) |
I asked where to get them on the Milton contact us page
Rick 88 Cab |
Boo
Rick 88 Cab Last edited by rick-l; 11-04-2015 at 08:05 AM.. Reason: fixed quotes |
the thing with the fittings is there are different types out there.
i would replace everything at the same time to make sure all are compatable. i have some that hiss when plugged in, drives me freeking nuts.
just crank up the tunes
![]() I have a habit of disconnecting a tool after use because they usually leak more when connected. I have yet to find one that doesnt leak. |
The Harbor freight coupler is a very similar design.
It might even be better. Note the finer body thread and the brass valve instead of the steel one that corrodes in the Milton coupler. The washers appear to be interchangeable. ![]()
Rick 88 Cab |
Friend of Warren
No, no, if you use the HF coupling your compressor will explode and it will make you sterile!
For the past 15 years, all my air tool couplings have been purchased from HF. None of them leak air.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I use these: Prevost IRC 061201 Coupler 1/4"Female Silver F/Mil727
They're the Porsche of air couplings. Cheap? Nope
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
