I've used pex only when I had to. Personally I would use copper in my own house. I would use type L copper. It's thicker than type M.
For ease of assembly, and to the budget, I would run PVC. Just make sure you clean the ends well, glue both pieces, support it where needed, and insulate it where it could see outdoor freezing air temps.
I prefer copper, but my well water has very high iron. So the copper deteriorates within a couple of years.
I've been using PEX for 20 years without a problem. It did have a bad rap years ago due to the aluminum crimp fittings expanding over time. They use a different crimp now.
| All times are GMT -8. The time now is 11:00 PM. |
