wdfifteen's Avatar
Originally Posted by Iciclehead View Post
Is Pex holding up in your region or are there similar life expectancies for Pex as you are seeing for copper?
Dennis
There are no corrosion complaints about PEX. The only problems I've heard of are related to untrained people trying to install it.
Old 11-12-2015, 06:11 PM
Retired Member
Brian 162's Avatar
I've used pex only when I had to. Personally I would use copper in my own house. I would use type L copper. It's thicker than type M.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 11-12-2015, 06:59 PM
For ease of assembly, and to the budget, I would run PVC. Just make sure you clean the ends well, glue both pieces, support it where needed, and insulate it where it could see outdoor freezing air temps.
Old 11-13-2015, 04:09 AM
I see you
flatbutt's Avatar
I prefer copper, but my well water has very high iron. So the copper deteriorates within a couple of years.
Old 11-13-2015, 06:42 AM
A930Rocket's Avatar
I've been using PEX for 20 years without a problem. It did have a bad rap years ago due to the aluminum crimp fittings expanding over time. They use a different crimp now.
Old 11-13-2015, 07:01 AM
canna change law physics
red-beard's Avatar
Mr Wdfifteen, one of the main reason they leak is at the joint where the stupid plumber use flux to cool the joint and did not wipe of the excess flux. It is not the copper, its human error also known as goddamnlazy bastards
Copper also suffers pin hole leaks, not suffered by PVC.
James
Red-beard for President, 2020
Old 11-13-2015, 07:55 AM
