fastfredracing's Avatar
Does this carburetor float look original to you ?
1965 Gto, This is the center carb of a tri power set up . It is a rochester 2 bbl, looks like every other one I have ever torn apart , although it has been a while .
Looks like some sort of sealant on the seam of the float, it is peeling off, and I found some laying in front of the one jet .
I only remember seeing silver solder on the seams of a carb float .
I think the real underlying problem is that it needs this carb cleaned out, fresh gas, new plugs , and another good run.
No left turn un stoned
Old 12-09-2015, 03:20 PM
Lap top crashed right when I was uploading photos,
Old 12-09-2015, 03:23 PM
Old 12-09-2015, 03:26 PM
I've never been good with carbs. I take 'em apart, blast the dickens out of everything with Carb cleaner, and put 'em back together with new gaskets. Most of the time that does the trick.
Of course I'm talking about 2 cycle carbs.
For the smaller Honda powered equipment I have (trenchers, etc.) I just buy a whole new carb on eBay ($15.00) instead of screwing around.
Old 12-09-2015, 03:31 PM
Can't say I recall seeing that on any carb float.
Is the band metallic?
Our '59 Pontiac wagon w/tri-power had the same carb setup, but I seem to remember the floats looking like they were just soldered together at the seam. If that ribbon is metallic it may have been someone's attempt at soldering the halves back together.
Scott
'78 SC mit Sportomatic - Sold
Old 12-09-2015, 03:33 PM
závodník 'X'
intakexhaust's Avatar
Definitely test the float before re-installing. Hopefully not a leaker.
Old 12-09-2015, 03:35 PM
The Unsettler
stomachmonkey's Avatar
May be Seal-All.
"I want my two dollars"
"Brandon Won"
Old 12-09-2015, 03:44 PM
There is no fuel in the float that I can make out, I will weigh it tomorrow, there is also a little dab on the bottom. Really looks like someones attempt at a repair. This center carb was acting funny, car would occasionally run perfect, then starve for fuel, once on the outer carbs, it runs 100 %.
Im having no luck finding a replacement as of yet, I may have to glue er back up , but I'd hate to .
I'll keep searching
Old 12-09-2015, 03:54 PM
závodník 'X'
Do the bodies look like... aftermarket or OEM? Are the fuel valves the same? Same goes for the power valves--? Are you first tuning with just the center carb, outers off w/block plate?
Old 12-09-2015, 04:06 PM
Still Doin Time
asphaltgambler's Avatar
Never seen a brass float look like that. Would search for new brass replacement
Old 12-09-2015, 04:52 PM
Found one. Ames performance, $7.00. that makes it a no brainer for me . Definitely not original. Thanks for your help
Old 12-09-2015, 05:18 PM
Preferred pronoun:Maestro
Norm K's Avatar
Ames has just about everything. It sometimes seemed I was personally keeping them in business during the couple of years I spent restoring my `70.
[IMG][/IMG]
When in doubt, use overwhelming force.
Old 12-09-2015, 05:29 PM
[IMG][/IMG]
OOOO that is sexy, my first cool car in high school was a 1970 black lemans. Always loved that era GTO.
Ames is great !
Old 12-09-2015, 05:36 PM
SoCal911T's Avatar
So YOU'RE the guy that bought my camera.
Old 12-09-2015, 06:17 PM
Ha ha ha, that is funny stuff right there. My cell phone camera was all smudged up .
Old 12-09-2015, 06:21 PM
I just assumed Byron was in town and took the picture for Fred.
Old 12-10-2015, 05:19 AM
Ah cmon man, they are not that bad, tough crowd... lols love you nut jobs
Old 12-10-2015, 06:01 AM
wdfifteen's Avatar
Hilarious!!
Old 12-10-2015, 08:35 AM
I thought it was close up of a gas tank.
Old 12-10-2015, 09:32 AM
That would either be a really small gas tank ,or I have huge thumbs .!!!
Old 12-10-2015, 09:55 AM
