-   -   How to remove these center caps?? (Sparco) (http://forums.pelicanparts.com/off-topic-discussions/895536-how-remove-these-center-caps-sparco.html)
Kraftwerk 12-19-2015 12:53 PM
Okay, so I have a 'car', temporarily that I am going to sell and keep the wheels.The previous owner gave me a tiny little piece of bent mental/tool he said you will need this for the center caps. He is difficult to reach these days, due to his new distraction GT4!! (--Porsche content!) So how the hell do i get the center caps off the tool seems more like a key.. and there is a tiny hole where it fits. Its the size of a tooth-pick and rather flimsy.
The wheels are sexy as-f. and not made anymore in this center - cap configuration: Sparco Rally wheels, I think they are called.. check em:
http://forums.pelicanparts.com/uploa...1450561979.jpg
stomachmonkey 12-19-2015 02:01 PM
They are just held on with clips.
Put the tool in and gently pull.
Kraftwerk 12-20-2015 07:36 AM
yeah the tool bent when I tried that.. the tool is really tiny and thin metal ... will try again have you personal experience with these? Thanks..
Wilywilly 12-20-2015 08:15 AM
I had some centercaps on a set of after market wheels which had a real small ex head set screw in them to keep the caps on. Is the tool a tiny allen wrench. If so try it that way
Nostril Cheese 12-20-2015 09:45 AM
Set screw most likely.
Did these come off a Ford Focus?
Kraftwerk 12-24-2015 01:23 PM
http://forums.pelicanparts.com/uploa...1450995684.jpg
Here is a picture of the 'tool' I was given to remove center - caps.. it bent when I used it as a mini-pry bar.. there is a small slot in the center where this tool fits.. but nothing inside the hole to 'unlatch'. It remains a mystery.. Wheels are on an MX-5.
masraum 12-24-2015 02:38 PM
I haven't had experience with that exactly, but 10:1, if you put it in the right way, I suspect it would push a spring bar of some sort. Can you get a better closer shot of the wheel/center cap?
Cory M 12-24-2015 03:19 PM
If tool doesn't work, take wheels off car and pop caps off with a piece of wood and a mallet. Put a towel on the ground or get a helper so the caps don't get scratched on floor when they come out.
masraum 12-24-2015 04:31 PM
THat would be a great suggestion for regular center caps, but if you look at the picture, the center cap in question cover's the lug nuts. I suspect it's hard to get the wheel off without first removing the center caps.
Eric Coffey 12-24-2015 05:04 PM
I would think they are just held in with spring clips as well, and maybe just stubborn due to dirt build up.
Or (and it's probably a long shot), the center cap might have locking tabs and lock into place via rotation. You might try putting the tool in a see if you can get the cap to move CW or CCW to "unlock".
Cory M 12-24-2015 05:19 PM
In that case, drive the car until the tires go flat, and leave it where it stops.;)
wildthing 12-24-2015 05:30 PM
If it doesn't move and it should, use WD-40. If it moves and it shouldn't, use duct tape.
Kraftwerk 12-25-2015 07:50 AM
^ I am leaning towards this suggestion.... ^
But I will have a closer look at it after the holiday. Thanks guys.
tevake 12-25-2015 09:03 AM
I know that reading the instructions is a last resort. But why not contact Sparco for their input.
Cheers Richard
wildthing 12-25-2015 09:06 AM
So funny. If you Google 'sparco center cap removal', the first result is a YouTube video, and the second and third ones are your threads, one in the Miata forums and this thread. Hehe.
patz 12-25-2015 10:10 AM
Take the wheel off, stick the back end the mallet or two inch wooden dowel into the back end of the cap. Give it a whack with another mallet.
stomachmonkey 12-25-2015 10:50 AM
How do you suggest he gets the wheel off?
patz 12-25-2015 11:06 AM
Ahhh, the pic didn't come thru on my monitor. Sorry.
Aerkuld 12-25-2015 11:31 AM
No experience with those wheels, but I have exactly the same type of tool with my OZ wheels for the center caps. With those I just hook the tool behind the center cap and pull - the center cap is just held in with spring clips and it pulls straight off.
I hope that helps . . .
Aerkuld 12-25-2015 11:32 AM
If the above doesn't work you'll have to use the sawzall
Kraftwerk 12-25-2015 11:35 AM
Thanks , yes I think these where made by OZ for Sparco, (no longer made..) but the OZ system is the same, will give it a try! Makes total sense..
stomachmonkey 12-25-2015 11:42 AM
Yes they are OZ.
You just need to apply gentle consistent pressure and they should just slide off.
They were known to sometimes "remove themselves" at inopportune moments like cruising down the highway at a fair rate of speed so guys would add rubber bands and even low tack adhesive products to keep them in place which makes removal more challenging.
