I see you
Computer display issue...need help
I have a TV as a second display on my desktop. It was working fine a few hours ago but now there is no signal from the desktop to the TV. Hard connectors are fine, re-booting didn't help...now what? I have an NVIDIA card in the desktop.
![]() TIA
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Make Bruins Great Again
Have you checked to see if the TV went bad? Tried a different cable?
See if NVIDIA has a self-checking program in the software drivers.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I see you
Don't have another cable...hmmm Will check NVIDIA tks!
Can you drag another TV over to see if it works with it?
Are your display properties still referencing the external/secondary monitor/tv ?
The Unsettler
Do you use a remote with the TV?
Maybe you bumped the input select button. Or the mirror display on your PC keyboard?
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I see you
WINNAH WINNAH CHICKEN DINNAH! Man I love the obvious fixes that I've overlooked. Many thanks guys.
I should get an assist since I suggested plugging in a different TV to see if it was the TV and not the computer.
