-   -   How To Un-Dent a Copper Mailbox??? (http://forums.pelicanparts.com/off-topic-discussions/898300-how-un-dent-copper-mailbox.html)
Don Ro 01-12-2016 12:06 PM
So with heat...do I use a micro torch, a bottle torch, or my heat gun?
Un-denting this thing is no longer my big issue - pisses me off that I can't find my dollies & hammers...especially my dollies.
If I can get something of weight on the inside I think that I can bring it back decently.
Been using a section of round 3" fence post on the inside, and on the outside using my little brass hammer as well as a 1"x2" 10" long hardwood w/rounded corners for a paddle/hammer.
It's thick copper...not a flimsy mailbox.
Thanks for the input, gents.
So far - -
http://forums.pelicanparts.com/uploa...1452629051.jpg
http://forums.pelicanparts.com/uploa...1452629084.jpg
id10t 01-12-2016 12:20 PM
That looks great. No more major trauma.
Maybe a mild acid treatment to give the whole thing a consistent "used" look/finish?
wdfifteen 01-12-2016 12:24 PM
Those are the stretched areas. You need to shrink it, you can't just pound on it from here. Heat it and pound the outside of the dimples toward the center from the edges while holding a dolly against them on the inside. The basic problem is you have .5 inch of metal to fit in .49 of space because the process of denting it stretched the copper. You can't just pound on it and make that go away.
Mark Henry 01-12-2016 12:28 PM
Once you have it done you need to clean it with something like alcohol (do a search) as the oils from your hands, etc., will make funny marks as the green patina appears.
Don Ro 01-12-2016 12:37 PM
Heat it with a heat gun, micro torch, or a bottle torch? Does it matter?
And heat the entire damaged area or just the small area I'm hitting?
"...outside of dimples..." Do you mean to tap on the high side of the dimples from the outside of the box?...against something held on the inside?
Thanks for the attention.
craigster59 01-12-2016 12:40 PM
Get some liver of sulfur from the local hobby store (Michael's, Hobby Lobby) to give it patina and call it a day.
ben parrish 01-12-2016 03:44 PM
I figured you would have used "$5 and a beer" to fix the dent:cool:
Porsche-O-Phile 01-12-2016 03:56 PM
I'd grab my small 4 ounce hammer and go to town on it to get a neat bush-hammered look going on. Lemons to lemonade. I bet it'd look awesome that way too.
Something like this: http://mailboxnet.com/clearance/mb5hplcp.html
wdfifteen 01-12-2016 05:26 PM
http://forums.pelicanparts.com/uploa...1452648005.jpg
The area inside the red circle has been stretched. To get the dimensions of the area inside the green line back to what it was, you have to shrink the red area. Heat the metal inside the red area with the smallest heat source that will get it hot fast and still limit the heat to that area. This will make the red area malleable while the metal outside green area is still stiff and will resist movement. Bumping the malleable area, while surrounded by a stiff area will give the metal no choice but to compress. Heat transfer is a time dependent phenomenon, so you have to work fast and probably try more than one iteration, letting it cool between tries. A heat sink outside the green area to keep that area cool and stiff will help. Let the metal cool slowly, fast cooling will make it brittle.
Make sense?
enzo1 01-12-2016 05:45 PM
Patina Formulas for Brass, Bronze and Copper
manbridge 74 01-12-2016 06:55 PM
Next time fill a bag full of water, put it inside closing door. Stand it vertical and stick it outside in temps around zero degrees. Oh wait.....
Don Ro 01-12-2016 07:28 PM
Make sense?
"Make sense?"
Yes it does.
I have a micro torch that I'll use...no dry ice but I have plenty of ice 'n rags.
Thanks for taking the time to draw this up & to write this.
The check is in the mail. ;)
Second thought...I"ll send you a copy of that Chicago hotel scene. :p
Don Ro 01-12-2016 07:51 PM
Originally Posted by enzo1 (Post 8955193)
Nice.
Thanks for this! :)
Don Ro 01-12-2016 08:33 PM
BTW, in my searching I found this...some good basic stuff...short 'n sweet.
http://neme-s.org/Model_Engineer_Files/2885-Dent%20&%20Bulge%20Removal.pdf
This day I've become fascinated with PDR...an art form.
This is nifty...
The Dent Eraser
1990C4S 01-12-2016 08:37 PM
Heat and ice is a bad idea for a beginner....you could make it a LOT worse. Be careful.
Don Ro 01-12-2016 08:46 PM
Yeah...thanks.
I ought to have waited until the Pelican wisdom showed up...that, and sought more info.
I'll snap a photo soon ...I think I may be done w/this...the side with the dent - and now my "un-denting" - will be close to the wall at my front entry so it won't show.
I just wanted to have some fun and experience w/it.
Not sure what I'll do with faux patina...I love the look of copper 'n brass together so I may just may leave it and let it age on its own...or hit it with some semi-gloss clear 'n be done w/it.
unclebilly 01-13-2016 01:32 AM
You should have used a rubber hammer on that sharp crease first. You do not want to stretch the metal any worse than it already was, which you did...
Worst case, put some if those bucket hole stickers on it...
Don Ro 01-13-2016 03:49 AM
"...bucket hole stickers on it..."
You mean bullet hole?
I did use a rubber mallet (1 1/2") from inside and outside...with a block of 3" fence post for backing on the inside and a block of wood on the outside for backing.
As I said, I couldn't find my dollies & hammers...and just as well, I guess...I would have made a mess, methinks.
I'll take a photo when I done/tired of it all. I'm becoming satisfied with what I've done.
Thanks.
dad911 01-13-2016 07:10 AM
Hide the dent: http://offbeathome.com/wp-content/bl...ox-300x300.jpg
Tidybuoy 01-13-2016 10:43 AM
Maybe you could search on YouTube and find a video of the dent doctor and how the massage the metal to pull out dents in cars.
