Funny thing is the mph and kph conversion is real simple
50km/h is 30mph, 60km/h is 40mph, 80km/h is 50mph, 100km/h is 60mph 120km/h is 75mph Those are not exact, for example I know that 100kph is really 62.1 mph, but it's close enough. At 100km/h or 60mph I will cover roughly the same distance in one hour. When I first began to drive I would do the conversion from mph to km/h, now it's km/h to mph. Also In case you're on the ball and noticed I used km/h and kph, both are acceptable. BTW it took way longer to type this, than to do the conversion, again I did the conversion in my head in seconds. |
UK continued to use SAE and Imperial standards e..g measurements, gauge, threads - in engineering for somewhat longer than that. But pretty much the only pre-decimalization measurement that remains now is the pint of beer/cider/milk. Sacrosanct. Oh, and troy ounces for precious metals. Quote:
After every fill I write the kilometres travelled on that tank on the gas slip and calculate the kilometres per litre. I confess that I then convert to miles per Imperial gallon, by multiplying by 2.84. :D |
Same reason the Chicago to New York train- takes hours longer than it did 100 years ago. Kind of.
Modern version: The Acella Train ( D.C. to Boston) was suppose to take x mount of hours but they translated the width off the tracks (inches) too wide compared to the spacing of the wheels ( Metric ) European train on American tracks. Train cannot reach top-speed.There is also the fact that the tracks are too "bumpy" which has less to do with measurement.. |
Just saw this on a knife discussion
http://uploads.tapatalk-cdn.com/2016...6a1a45559f.jpg Sent via Jedi mind trick. |
The Apollo Guidance Computer was programmed in SI, but displayed and accepted data in English units. ;) |
Anything out of the normal car speed range and I'd likely have to do the math. I no longer convert most measurements, it's the same as learning a 2nd language, if you use it every day you will be fluent, if you stop using one you will forget quickly. |
"Why aren't we using the metric system?? "
We are. The US uses both. I use SI daily. (engineering) And don't drug dealers, for the past 5 decades, sell by the gram? or is it oz? |
| All times are GMT -8. The time now is 02:06 PM. |
