I guess the good news is I did order a cable tester.
I was playing with my new cable tester yesterday and connected it to the garage run. The lights were all over the place. I must have been color blind when I connected the jack in the garage (and when I double checked), because it wasn't even close. I guess you can wire up the jacks wrong and they will still work.
I also found patch cables that i made that were working, but wires were crossed. |
It's also been at least 10 years since I've seen even a consumer grade switch that wasn't capable of establishing a valid link across at least 150 meters of decent CAT 5 or 5e cable. Length should not be an issue for you. Gary |
| All times are GMT -8. The time now is 07:26 AM. |
