Need 3D modeling software to send to a printer
I need to create some simple, proof of concept prototypes using a 3D printer. I downloaded DesighSpark Mechanical and installed in on my Mac running Parallels and Win7. It installed fine but wouldn't run.
Any recommendations on 3D design software for either Mac or Win7?
Tru6 Restoration & Design |
The Unsettler
The higher end stuff Lightwave, 3DS Max, Cinema 4D etc... generally have steep learning curves and are pricy.
Then there is google sketch up which has never really floated my boat. A very powerful one, commercial grade that is multi platform and open source is Blender. I never dug it's UI though. The question is how much can you tell us about the object, meaning is it a more organic shape or multi part mechanical? There are different types of 3d modeling apps that are better suited for one vs the other. Some use basic shape, boolean and spline based modeling while others work more like modeling clay. I've heard good things about Sculptris but have not had a chance to take it for a drive. Pixologic :: Sculptris Multi platform and free.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Thanks Scott, I need to make several versions of C channel, some straight, some curved, some based on a wide flat plane, etc. with different shapes of channel... I'll probably test 10 versions to see what works best. Pretty simple stuff at the core of it.
I will check these out over the weekend, appreciate the suggestions.
Banned
can any of the 3D printers do wax
to do a lost wax mold of the printed model and cast a real metal part ? |
Platinum Member
I could do it in Solidworks pretty quickly, can you send me some sketches?
Slackerous Maximus
Google sketchup floats my boat, but the SOBs charge money for it now.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Dad, thank you, I appreciate the offer. Unfortunately I can't as the designs may be part of a patent application. It's something I need to rough out just to see if my idea will work and then have a design firm take it from there, or drop it if it doesn't work.
finished part material is TBD based on prototyping.
Now in 993 land ...
Sketchup is a POS. No longer Google from what I gathered. I used it for some 3d sketches for presentations and it was not fun.
I need to find a good freeware CAD program. Last I used was AutoCad looong time ago. Curious to see what you all suggest. Thanks, Georg |
Platinum Member
Then I would suggest Autodesk 123D, free and fairly easy to use. And it will directly export stl files for printing.
What?
Try onshape, a free 3d cad, Internet based program.
Www.onshape.com
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
Thank you.
The Unsettler
Ignore my suggestions. Others have made some good ones.
Platinum Member
![]() Thank you, I like this better than 123d....... alot like solidworks. I did above in about 5 minutes. |
It'll be legen-waitforit
What's everyone got for 3d printers? My kids are taking a robotics class today and all the parts are 3d printable.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
My son gave me one from Monoprice.com. It's the Architect model.
Scott '78 SC mit Sportomatic - Sold |
I use Form•Z for my modeling. Pretty intuitive and very powerful. There is a lower priced version called jr. and a free version too.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
What about Fusion 360? It is by Autodesk and is free for individual use. After 1 year, you just renew it again (or so I have have read). You download a dedicated interface/browser and it requires an internet connection. I assume this is some sort of 'cloud' application.
Who, What, When, Where, Why and How. |
If you are indeed concerned about keeping design work under wraps for patent purposes, I recommend running something locally on your equipment and not working with cloud-based CAD.
