Is dolly tire patch-able?
Thinking of pouring in a sealant.
Or can I get to the inside to stick on some bike tube patch? I looked at new tires and they cost more than the dolly. ![]() ![]() Sent via Jedi mind trick.
poof! gone |
Owned the thing maybe 20 years. Loan it out and. Voila!!! First hole in the tire.
poof! gone |
Make Bruins Great Again
Tube generate a lot of heat. Not good for long distances or highway.
Sealant probably is fine. Ask your local tire guy (who you trust).
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Model Citizen
Get a new tube. Harbor Freight.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Model Citizen
It's a two-wheeler dolly. Doubtful it will see much highway or high-speed use, but this is vash....so, .....
This is a hand truck/dolly? Tube would work or a plug or pop it off and patch with a regular patch.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Eh? Don't buy a tube. It's cheaper and easier to buy the whole wheel/ tube/ tire assembly at either Harbor Freight or Tractor Supply. When you have a fleet of them ( I have a fleet of them), that's when you start buying tubes, tires, bearings etc.
Tube is only like $5 at Walmart and the tire comes off with a couple od screw drivers. Just went through that with my pressure washer.--Dave
No that's a two piece wheel. It's easier than your one piece. But my point is that you still have an old bearing, etc. Just change the whole thing. I justify changing out parts, but that's because I have close to 80 tires that need servicing.
Only $5.99 for whole brand new wheel at Harbor Freight
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Sorry. Hand truck!!
poof! gone |
weekend wOrrier
I've never had much luck with the goo on these small pneumatic tires.
Then again, I've never had too much luck with these small pneumatic tires. I absolutely hate these cheap chinese things. So I'll thow out yet another opinion- If I were in HF, I would look into replacing both those tires with solid wheels! ![]() There is nothing worse than sitting a heavy appliance on a hand cart and realizing that one wheel is low on pressure. Last edited by LEAKYSEALS951; 07-05-2016 at 01:25 PM.. |
The goo stuff breaks down in hot weather. If you want to go cheap, then get the Slime patch kit. The tube can be repaired if the valve stem hasn't broken off. Takes about 15 minutes. Use a bucket of water to locate the hole. It's easy if you have an air compressor.
Anybody else besides me find it sad that in today's society we don't even think twice about replacing something like this rather than fixing it?
Scott '78 SC mit Sportomatic - Sold |
Monkey+Football
Bike tube repair kit. Same as you'd patch any inner tube. 5 minutes. Did it 3-4 times before when we had to dolly equipment across a construction parking lot.
Amazing how many geeks don't know how to do something slightly mechanical.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
Oops, a hand truck? Don't they still make the plugs? I wouldn't use one for a car but for a hand truck why not? Either way, don't take it on the highway...
You don't put a plug in a tube. Patch.
I have tubes in mine. I just make sure t0 wear my helmet and strap in real good in for sustained high speed runs
![]() Been like this for 3 years now, easy peasy, no leaks, no problems
No left turn un stoned |
RETIRED
This^^^^^^^^^^^^^ BTW, mine is tubeless, popped bead, aired it and it had no leaks after being dumped in a bucket. Musta had some schmutz in the bead.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 07-05-2016 at 02:27 PM.. |
I vote tube. I'm pretty sure that I converted mine to tube a while back because it wouldn't hold air.
