Interesting suspension upgrade as stand alone or for PASM
I've been reading a bit about this lately.
DSC Sport It's available for 996, 987 1 & 2, 997 1 & 2 and 981 or 991. The 9x7.1 cars need a separate 3 axis accelerometer because the factory unit is only 2 axis (except turbos and GT3, I think which came with 3 axis). It's also avialable for Vipers. If your car has PASM, then it's a direct swap of controller (with 987.1 and 997.1 cars requiring the additional 3 axis accel that comes with it). It works with the Bilstein Damptronics too. If your car didn't come with PASM, but there is a stand alone option. They also have a version that comes with high end aftermarket shocks that are more advanced than the Bilsteins. As I began reading, I wondered how this box could be an improvement over the Porsche setup. This box talks about stiffening the front upon braking, the back on acceleration and the outside on cornering. But then the stock PASM controller is supposed to do all of that. Eventually reading though a long thread on RL, I found their explanation about how/why their box offers improvement. Apparently, the stock PASM setup uses a very limited portion of the stock shocks range while the DSC box uses much more of the range. <iframe width="853" height="480" src="https://www.youtube.com/embed/-nOYsPNaNqI" frameborder="0" allowfullscreen></iframe> Here's a quote from a post by DSC on the RL forums. Quote:
<object id="flashObj" width="480" height="270" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,47,0"><param name="movie" value="http://c.brightcove.com/services/viewer/federated_f9?isVid=1&isUI=1" /><param name="bgcolor" value="#FFFFFF" /><param name="flashVars" value="videoId=4331475436001&playerID=219609610200 1&playerKey=AQ~~,AAAAlDCBGhk~,VcmqiTAuekrwPweJ20LL t7jwm8LxmhCE&domain=embed&dynamicStreaming=true" /><param name="base" value="http://admin.brightcove.com" /><param name="seamlesstabbing" value="false" /><param name="allowFullScreen" value="true" /><param name="swLiveConnect" value="true" /><param name="allowScriptAccess" value="always" /><embed src="http://c.brightcove.com/services/viewer/federated_f9?isVid=1&isUI=1" bgcolor="#FFFFFF" flashVars="videoId=4331475436001&playerID=21960961 02001&playerKey=AQ~~,AAAAlDCBGhk~,VcmqiTAuekrwPweJ 20LLt7jwm8LxmhCE&domain=embed&dynamicStreaming=tru e" base="http://admin.brightcove.com" name="flashObj" width="480" height="270" seamlesstabbing="false" type="application/x-shockwave-flash" allowFullScreen="true" allowScriptAccess="always" swLiveConnect="true" pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash"></embed></object> I have to say, I'm curious. Most of the postings that I've found on various forums on the 'Net are from folks that think this is a huge improvement over stock. Apparently, as a customer, you also get access to the software that allows you to custom program the shocks if you want, and you can upload maps and share them with other users. I think the maps should to be shared among similar car layout vehicles, IE, 911<>911 and boxster<>cayman. |
Very happy with these as a replacement for stock PASM, yes there are only two settings in PASM, these offer a bit more manual setup, but hit the PASM button and it's go cart good.
http://forums.pelicanparts.com/uploa...1468609999.jpg |
The Porsche setup says that it tightens things up when you are in normal mode, but driving more aggressively, but I can't tell that it changes. And per Porsche, if you hit a bumpy section but you're in Sport mode, the controller should soften the shocks to help with the bumps, but with the stock system, it doesn't seem to cope well with rough road in Sport mode. The theory is that this aftermarket controller gives you a more dynamic setup in both normal mode and sport mode. All of the reviews that I've read on various forums have people singing nothing but praises for it. Most of them are 997, 997tt, 997 GT3, 991, and a few Cayman GT4s. I haven't seen much from the Coxster crowd. You can get a kit that's just the controller. It will work with the stock shocks, your Bilstein Damptronic shocks and at least one other set of aftermarket coilover. You can also get a kit with the controller and a set of those aftermarket coilovers. Plug-n-play controller with 3 axis accelerometer required for 997.1 and 987.1 http://cdn.shopify.com/s/files/1/056..._1024x1024.jpg |
I have one in my 997S. Was skeptical at first, but wanted to install one to test it to see if we would offer this product to our clients. It is flat out amazing. On a 997.1 you pick up an extra mode (3 total) and have access to all of the variables for tuning your own maps. Transformed the car in terms of feel and ride comfort, even on the stiffest "race" setting.
Cheers |
http://rennlist.com/forums/997-gt2-gt3-forum/856864-official-dsc-sport-discussion-forum-9.html#post12882865 Quote:
| All times are GMT -8. The time now is 08:10 PM. |
