I have been to the Winnebago factory in Forest City, Iowa and they do a lot of the install without the body on. I have had to cut things out and then modify how I install the replacements.
Find a good plumbing supply place, and they can hook you up.
Bill
Old 07-18-2016, 03:53 PM
sugarwood's Avatar
I use micro flush cutters to tear it apart, by unraveling them
1986 Bosch Icon Wipers coupe.
Old 07-18-2016, 04:19 PM
Detached Member
Hugh R's Avatar
Ordered a PEX crimper that will do 1/2, 3/4 and 1 inch and two dozen assorted clamps from Amazon for $32. 25' of 1/2" tubing at HD for $8 so I'm good.
If I can fix a leak in a 3 year old RV for $40 and an hour or two of work, I'm delighted.
Old 07-19-2016, 04:49 PM
Duly noted for the 3 year mark, the precipice on which RV ownership delight turns to dreary loathing. Wait till you have to fix a leak in the shower. Or the poo poo tank. Or the water heater....or....
Old 07-19-2016, 05:45 PM
Detached Member
Hugh R's Avatar
All buttoned up. Used the PEX tool and pressure tested everything, no leaks. Yeah the toilet dribbled between it and the blackwater tank. Pain in the ass to fix, the blackwater tank seems to have been installed before they put the exterior siding on. But I'm done. At least I got to see where my water pump, etc. is located. Also, as long as I was "in there" I ran a cable for the Direct TV to the far right of the enclosure so I don't have to run it through the window anymore.
Hugh
Old 07-23-2016, 06:29 PM
Band.
Nice work, congrats!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 07-23-2016, 06:30 PM
Detached Member
Hugh R's Avatar
You are 100% correct. I have to remind the trophy bride that if a cabinet doesn't close right, don't keep slamming it. I may need to tighten a hinge or latch screw or stick a few toothpicks into the hole with glue for the soft wood.
Old 07-23-2016, 06:55 PM
