2004 Tahoe dashboard question
We've got a 2004 Tahoe with 115k on the clock that we got from my brother a couple of months ago.
The truck runs great but the dashboard has just gone out. No gauges work. A few bangs with the hand on the top, sides, etc didn't help. :) Any idea where to begin? |
Been there done that- had a 04 Tahoe. Great car.
This is a known failure point. There are several online sources that can rebuild it for $100 or so. I used one- I think but cannot confirm it was $99 GM Cluster Rebuild Pulling the cluster is easy. Took about 10 days or so turnaround time including shipping. Drove the car with no issue without the cluster. 10minute job to put it all back together. In my case, the repair lasted about 2 weeks- then went dead again. They were great- sent me my money back. Because of other issues I sold the tahoe at that point. Other options- a new cluster from chevy. I believe it was about $750 + labor. You can buy rebuilt clusters at any auto parts store. $250-300 I believe. I did not go that route as there can be issues assigning it to your car, mileage transfer, etc. If I were you I would pull the cluster and try to get it repaired. Most have better luck than I had. Gary |
I've fixed them. 03 GMC Pickup, probably the same.
2 problems, the 'resisters' heat up, and actually melt the solder connection to the board. I had to touch up the solder connections. The stepper motors and lights for the gauges burn out, you can buy them cheap on Amazon. |
Thanks guys. I'm not a real electronics person and will probably just send it out.
Dumb question but did you check the fuses?
lol. Of course I didn't check the fuse! I figured there was some catastrophic failure the PPOT crowd knew about.
| All times are GMT -8. The time now is 09:18 PM. |
