-   -   Removing rusted nuts using a candle and a lighter (http://forums.pelicanparts.com/off-topic-discussions/933766-removing-rusted-nuts-using-candle-lighter.html)
Baz 10-27-2016 07:50 PM
Going to try this on my boat trailer........looks promising......
LiveLeak.com - Removing rusted nuts using a candle and a lighter
LEAKYSEALS951 10-27-2016 08:07 PM
somebody try that with spark plugs if you get bored!
astrochex 10-27-2016 08:55 PM
There is some skepticism in the comments.
Don Ro 10-28-2016 12:45 AM
Amazing. Learn something new every day - hopefully.
Thanks Baz.
M.D. Holloway 10-28-2016 03:50 AM
Interesting. So the liquid state wax flows to the interface and upon cooling it establishes a boundary film regime allowing for a reduction in the coefficient of friction. It would be an interesting experiment to compare this to Knock-Up (CRC), Kroil, and PB Blaster, WD40.
targa911S 10-28-2016 05:38 AM
Knock - Up? Hmmmm.... Whats in that stuff?
javadog 10-28-2016 08:00 AM
I just tried candle wax on some stuck fasteners I've been heating with a heat gun and soaking with Kroil for months. Used the same heat gun, wicked some wax into the threads, they came right out.
New tool in the toolbox...
JR
E38Driver 10-28-2016 08:04 AM
I have used wax and heat for many years. Mainly on very old pipes nipples fro having worked in a building that was 50+ years old.
As you heat the wax if you see bubbles at the joint that is a good thing. Let the wax get in there and twist it off.
fastfredracing 10-28-2016 08:05 AM
Im going to do my own shootout here in the shop , next chance I get. Should not take long, rusty fasteners are a daily battle here . I usually just go for the torch, and heat everything till it glows , then walk it off.
David 10-28-2016 09:07 AM
Beeswax on stuck fasteners is a standard procedure around here.
gatotom 10-28-2016 09:19 AM
Thank you, as they say learn something new every day
blucille 10-28-2016 09:27 AM
wonder how that would do on heat exchanger nuts
nota 10-28-2016 09:47 AM
some shops also use wax in place of oil on drill bits
as if the wax drips off the work
it quickly hardens and does not run off
Hawkeye's-911T 10-28-2016 10:07 AM
Old hot-rodders used to tell of this trick. Dude has nice shop safety shoes
Cheers
JB
SCadaddle 10-28-2016 10:10 AM
I used beeswax in the form of a "Berts' Bees Peppermint Lip Balm" chap stick like applicator in removing the Dilivar head studs on my 911SC. Worked like a champ.
ckissick 10-28-2016 02:58 PM
Unlike Kroil, et al, the wax will stay on the threads for a long time. So will a newly installed nut be prone to loosening?
cashman 10-28-2016 03:52 PM
After all the 500 threads on which is better ( kroil, PB Blaster, ATF), how is this the first time its been mentioned here?
stealthn 10-29-2016 06:23 AM
Wow good to know
Cajundaddy 10-29-2016 06:40 AM
Nice! I love shade-tree solutions to age-old problems. Rust never sleeps and this trick applies to so many different stuck fasteners. Need to try this on some nasty header bolts that usually piss me off.
flatbutt 10-29-2016 11:54 AM
Just remember to do it bare footed.
