-   -   TV sound bars. How can they be so confusing?? (http://forums.pelicanparts.com/off-topic-discussions/934860-tv-sound-bars-how-can-they-so-confusing.html)
Gogar 11-11-2016 02:31 PM
Is the a cox remote and the tv remote, or just 1?
craigster59 11-11-2016 02:32 PM
There should be instructions that came with the sound bar on syncing your TV remote. Double check or do a web search on the model.
G50 11-11-2016 02:54 PM
The system is using just the Cox remote.
Is there a way to sync that remote to work with both the Cox box and the soundbar?
edit/
Here's the remote and instructions. Looks like maybe there is. Although the instructions aren't that clear. How does it know what kind of soundbar I'm using??
https://www.cox.com/content/dam/cox/residential/support/tv/print_media/URC_8820_v2_user_guide.pdf
craigster59 11-11-2016 03:18 PM
Looks like the code for Samsung is 2660. Just follow the instructions on programming Cox remote for "audio accessory".
Gogar 11-11-2016 03:39 PM
Yep
masraum 11-11-2016 05:07 PM
Based on the manual for the TV that you provided earlier, using the optical cable will require you to use the sound bar's remote and using the optical cable will only work when you are getting a 5.1 broadcast.
I would think that the only way that you'd be able to control the volume with the TV volume would be if you had some other sort of audio out whether it be RCA or headphone or maybe HDMI or wiselink. It doesn't look like you've got ANY outputs on that TV other than the Optical. Everything else in your photo looks like it's input.
But, I would think that the Cox remote should be programmable for the sound bar which I think the other guys have mentioned. I think that Craigster looked at the manual and found the code for the remote for you.
willtel 11-11-2016 07:16 PM
911 Soundbar | Porsche Design
http://www.porsche-design.com/out/pi...web_slt_02.png
Gogar 11-11-2016 09:20 PM
The cox remote will do it. Just like a directtv remote.
G50 11-11-2016 10:47 PM
My 76 year old pops and I thank you!
Programming the Cox remote worked. The built in speakers on that Samsung TV were horrible. really unlistenable.
Sounds great now tho!
Gogar 11-12-2016 06:18 AM
Awesome!
