-   -   pro auto mechanics. why the tight oil filters? (http://forums.pelicanparts.com/off-topic-discussions/938213-pro-auto-mechanics-why-tight-oil-filters.html)
vash 12-06-2016 10:24 AM
i have yet in my relatively young life come across an oil filter i can take off easily after a visit to a shop. if i do the oil change, i can take it off by hand with a big square of that fabric i line my shelves with (anti skid stuff, under rugs).
i had to do the subaru oil change this past weekend. i looked and the last change was done by an indie shop when the car had to go in for major surgery. sure enough, the filter was unturnable by hand. i had to resort to a big pair of slip joint pliers.
do pro mechanics simply have stronger hands than me? or are they using a wrench? i kinda spin them on and do the 3/4 turn thing and look for leaks after a refill and motor start. i never leak at the filter.
1990C4S 12-06-2016 10:29 AM
They typically use the adapter that drives the end of the filter I think. Or the wrap around clamp.
Better for them to go too tight and not leak. Odds are someone else is removing it.
oldE 12-06-2016 10:35 AM
Never underestimate the torque generating ability of an azhole.:mad:
Best
Les
kach22i 12-06-2016 10:39 AM
Same with lug nuts, always too tight.
Baz 12-06-2016 10:43 AM
Who doesn't change their own oil?
That's asking for trouble.... ;)
rockfan4 12-06-2016 10:44 AM
If you've never seen a filter gasket get pushed out by thick oil on a -10 degree morning, then you've never had a too loose filter. On the other hand, I had a Audi spring leaks from pinholes in the case caused by the dealer installing it with a wrench.
Joe Bob 12-06-2016 11:01 AM
On a cross country trip from CA to FL, I forgot my oil wrench and took it to Wally World for an oil change prior to the return trip. Hey, I had a coupon....It leaked over night and was a Fram (as we all know Fram sucks), contrary to my request. They re-installed the right filter......cranked it down.
Back home after 3K miles I changed it myself and it took awhile to get it off, Fortunately it was on my Honduh, so no loss. Complaints to WW got no joy. Never again.....
fastfredracing 12-06-2016 11:15 AM
Some of them are just some *****es. I only hand tighten, 3/4 turn, and I have had my own filters come back and struggled to get if off.
That being said, some guys are just freakin' He man and crank them down TIGHT. Most of of us have king kong grip from years of twisting wrenches
9dreizig 12-06-2016 11:34 AM
under tight and pay for an engine that blows up if it works it's way off.. simple
widgeon13 12-06-2016 11:44 AM
I change oil on my Pcar and my plane. On the car it is hand tightened and on the plane it is set at a specific torque setting (w/ a calibrated tool)and then safety wired. I can't hand remove either one after they have been run for the usual change oil cycle.
wdfifteen 12-06-2016 12:01 PM
It might be the experience and stronger hands. If you're working for money you lose time wrestling an overtight filter off, so there is no advantage to cranking it down too tight if you ever expect to see the car again.
Hugh R 12-06-2016 12:07 PM
On the 911 the first thing I did when I got it 12 years ago was oil and trannie fluids and all filters. The trannie fill plug was so tight, I rounded off the sucker trying to get it off. I used a clench wrench to finally get it off, but it destroyed the plug.
Learned long ago, you always pull the fill plug first, not the drain plug.
rusnak 12-06-2016 12:53 PM
^ Good advice.
What's a clench wrench? You mean a nipple extractor, like a plumber uses? I can't get the transaxle plug out of the 911. That thing is just hopeless. I change oil by removing the access cover, what a PITA.
Vash,
I have the socket oil filter wrench for all of my vehicles. That's also a PITA too because every car seems to use a different socket tool, and the Cayman needed a Hazet oil filter wrench which wasn't cheap.
Hugh R 12-06-2016 01:01 PM
Like this, Craftsman - 37002 - 2-pack Ratcheting Clench Wrench | Sears Outlet
You can get much cheaper, on my 911 trannie fill plug there was just enough threaded metal to use one of these. It will destroy the plug, but at least you can get it out.
Baz 12-06-2016 01:23 PM
Thanks for the info on this wrench, Hugh. I just bought the same set by Craftsman from eBay ~$20 incl. shipping - will be here on Friday. :)
Geary 12-06-2016 01:37 PM
I had a shop change my trans oil once. Never again. They torqued the oil add plug to 100+ lbs, when it called for 15. These days I use teflon tape. Never had a problem. With oil filters, I typically tighten a second time, after a few hours running.
rusnak 12-06-2016 01:49 PM
You mean, silicone right?
I kid, I kid.
masraum 12-06-2016 01:55 PM
I'm voting laziness and incompetence.
I doubt if they lube the gasket before they install. I always do/did.
I suspect they just crank it down with their hand because they are in a big hurry.
People with no place to do it. :D
manbridge 74 12-06-2016 02:12 PM
Meh... never had a filter I couldn't get off quickly. I do use the specific optimol grease on the filter cup o-ring. In my experience filters don't seem to just come loose. Problems occur because they weren't ever tightened at all.
But drain plugs, man I've seen some tight ones.
1990C4S 12-06-2016 02:13 PM
You mean teflon tape on the plug? It's okay on a transmission plug, I would never use on engine plug. Teflon paste is much safer.
rusnak 12-06-2016 06:14 PM
Copper washer. Or aluminum.
wdfifteen 12-06-2016 06:29 PM
Gotta tell this story here>
When I owned my shop this happened twice. Time frame early 1970s. Saab 96 V4 comes in smokin' like a sum*****. In both cases the owners had tried to do their own maintenance. I both cases they drained all the oil out of the transmission and added four quarts to the engine. The transmission is in front of the engine in those cars - from underneath it looked like where the engine plug should be - and that was very unusual in those days. Read your owner's manual people.
manbridge 74 12-06-2016 09:06 PM
Furthermore, at least for most newer cars, copper washer generally used where surfaces are steel to steel. Aluminum washer where one or both surfaces are aluminum.
Older Porsche's do use aluminum washers on steel oil tank to steel plug though.
speeder 12-06-2016 10:53 PM
Originally Posted by pmax (Post 9386132)
This.
Better to overtighten than have the customer return with an oil leak.
For sure, a loose oil filter will cause a major mess but usually immediately or very quickly when it unscrews itself under pressure, in my experience. I've only had one filter come loose on me and it was a mess, it was a (then new) Saab 900 and I made the classic error of leaving an old rubber seal on the engine and installing the new filter over it. Long time ago but lesson learned.
If you install a new filter w a little clean oil on the sealing rubber and make sure that you did not leave the old rubber seal on motor, they are usually easy to properly tighten by hand. And as others have mentioned, they tend to get tighter in use, not looser. :)
on2wheels52 12-07-2016 04:20 AM
Try using the oil that just drained on the filter gasket.
KNS 12-07-2016 04:22 AM
The only oil filter I ever had leak was a Porsche brand oil filter, the smaller one on the 993. It was leaking right at the mounting surface, strange - it was not loose. I'd heard of a few issues with the small Porsche 993 filters so I went back to Mahle.
Porsche-O-Phile 12-07-2016 04:24 AM
"Have the new guy do the oil changes and tire rotations - he won't do any harm that way".
WRONG!
The issue is that "harm" to a shop owner is "having to redo work myself" or "fix the kid's screw-ups", not actual damage to YOUR car, which they don't give a fig about.
Tools are incompetence magnifiers. Power tools extremely so...
KNS 12-07-2016 04:32 AM
As far as dealers go - I changed the oil recently on my son's Mazda, its second oil change. The first one had been performed by the dealer. The drain plug required a hex socket to remove but I guess the Mazda tech didn't have one. It was mangled by what appeared to be channel locks or pliers along the outer edges.
GH85Carrera 12-07-2016 05:34 AM
We just ordered a new Macan. In looking around online to see the procedure I noticed the going rate is $400! for a dealer oil change. Our dealer said it was $240.
It looks like I will be doing the oil changes myself. Pelican Parts needs to start a Macan forum and sell Macan parts now. ;)
At least I hope I can get the oil filter, gaskets and such from Pelican.
asphaltgambler 12-07-2016 10:12 AM
The reason is more simple. The rubber gasket/O-ring that seals the filter is exposed to heat and oil which is petroleum based. The seal will swell slightly increasing the torque required to remove regardless of how tight it was originally. Further even pure synthetic oils will eventually have byproducts of combustion, which are petroleum based.
This is of course only relating to canister style filters. I've found that installing the filter by hand ( lubing the seals ) spinning it until resistance is felt, then another 3/4 turn works every time. If its a diesel canister filter, same method but full turn additonal due to vibration, thicker oil viscosity when cold.
Otter74 12-07-2016 10:21 AM
I install filters to finger tight plus half a turn, and I have only ever had to gorilla a filter off when I broke this rule and tightened it something like a full turn for some reason. Only time I've ever had a filter come off was when I was putting a new engine in my old Infiniti G20, and the filter adapter and filter were mismatched - the threading was slightly different after a certain build date and I had adapters and filters from both eras, so everything looked compatible but wasn't, and I put the wrong filter on. Filter started spewing oil immediately on startup, so it wasn't hard to miss and I replaced with the correct filter.
stevej37 12-07-2016 10:42 AM
I've never heard of tightening a filter after a few hours? Wouldn't that just cause the seal to have to renew?:confused:
tcar 12-07-2016 11:06 AM
... These days I use teflon tape...
Teflon tape is not rated for high temps.
john75 12-07-2016 02:13 PM
I'm so glad to hear that other people have under-tightened an oil filter! I did my first oil change this year and followed the instructions which said to hand tighten the oil filter. Apparently I have girlie strength for-arms because I had oil spraying out the sides of the oil filter. Turned off the car, did further turn on the oil filter with a loop wrench (not sure of the name) and it has been good to go.
To those who have done a similar move...how did you clean the oil in the car?
manbridge 74 12-07-2016 04:18 PM
Get a mild degreaser at a FLAPS and let it soak in a bit then rinse with water. Do it over cardboard if you want to throw out the mess.
Geary 12-07-2016 04:29 PM
The quote it taken out of context. I was speaking of transmission oil plugs. Teflon tape does not "deteriorate from heat" when used on trans oil plugs. For an engine drain plug, a crush washer or copper washer is typically used.
rusnak 12-07-2016 07:54 PM
My Chevy 1-ton truck with a 454 motor is very hard on everything. Never had a vehicle that would wear things out like it does, and it's also the only vehicle that will work the oil filter loose if it's not tightened beyond hand tight. I use the oil filter socket on it, as I mentioned, for both installation and removal. I don't go gorilla tight on it, but not baby tight either.
RANDY P 12-07-2016 09:32 PM
3/4 of a turn from barely touching, and that's all.
Same thing with a home water filtration unit. Huge volumes, and you attempt to tighten one with a wrench, you are doomed come next time you have to change. It requires deceptively little torque to seal.
rjp
speeder 12-07-2016 10:06 PM
Not so, the transmission is behind the engine. But from underneath, the trans drain plug is in a location that could be construed as the bottom of the engine if there wasn't an engine with an oil pan and drain plug just in front of it. If the car was on a hoist and someone did what you describe, I just don't know what to say. :confused:
I currently own a 1970 Saab 96, it's my 4th one over a period of 40 years.
jwasbury 12-08-2016 05:26 AM
I feel your pain Vash --->
Open letter to the Gorillas who work at the dealership - North American Motoring
