Shaun @ Tru6's Avatar
Can you add a rheostat to a buffer?
I have a bench top buffer that spins at 3600 RPM. I want to slow it way down to 500 to 2500 depending on what I'm doing. Can you wire one in that will slow the motor speed? Will it hurt the motor in any way?
Developed a new polishing technique that requires many different speeds.
Tru6 Restoration & Design
Old 12-13-2016, 05:23 PM
The Unsettler
stomachmonkey's Avatar
Variac.
$50-60 on Amazon.
Or get a router table speed controller. HF has them for like $20.
Just plug it in and go.
"I want my two dollars"
"Brandon Won"
Old 12-13-2016, 05:53 PM
Charles Freeborn's Avatar
Depends on type of motor. If universal (with brushes), like a router or drill, yes. Induction, no. You can speed control an induction motor only if it's engineered to be variable speed.
What You Must Know About Motors - Popular Woodworking Magazine
Old 12-13-2016, 05:59 PM
Like this? It might limit your top end speed, but if you need more speed maybe you can wire in a bypass.
Old 12-13-2016, 06:02 PM
Platinum Member
dad911's Avatar
I believe that will reduce power considerably.
Can you use a smaller diameter wheel? That will reduce the surface speed at the edge of the wheel.
The 'porsche' mod would be a 3 phase motor with a VFD.
Old 12-13-2016, 06:06 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
swap out the gears...
Michael D. Holloway
https://5thorderindustry.com/
Old 12-13-2016, 06:14 PM
Variac.
$50-60 on Amazon.
Thank you! Here's the spec plate (looks like 3450 RPM), which one do I need to get? It's a 1/2 hp motor.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=Variac
Old 12-13-2016, 06:28 PM
The wheel size I use is important so I have to stay with that. What do you think of the Variac that Scott posted?
Old 12-13-2016, 06:31 PM
Platinum Member
dad911's Avatar
No experience with Variac, sorry.
Old 12-13-2016, 06:43 PM
id911T's Avatar
Looks like an induction motor. The 3450rpm gives it away. You will need a single phase VFD to vary the speed. If the motor wasn't designed for a VFD, you will be limited on how much you can reduce the speed though.
Stephen
GruppeB #906
1970 911T
Old 12-13-2016, 07:19 PM
The Unsettler
It is a single phase motor.
Marked on the tag.
You are not going to slow that down easily or cheaply.
You'd be better off and probably save money by swapping for a 3 phase.
"Brandon Won"
Old 12-13-2016, 07:51 PM
Or swap it out for a 1725rpm motor. To run a 3 phase you have to have 3 phase power to your shop.
My buffer is belt drive so I can change speeds with different pulleys.
A variac will not work on yours.
Old 12-13-2016, 08:30 PM
Used variacs in the lab all the time for stir bars and plates, hot plates, round bottom flask heaters. Used to hook them up to motors but all were 1725 if I recall.
Michael D. Holloway
Old 12-13-2016, 08:52 PM
Marked on the tag.
OK, thank you. I have 3 phase for the Cerakote oven but sounds like it's more trouble than it worth now.
Old 12-14-2016, 03:30 AM
Automationdirect has a lot of cheap VFD drives.
Their selection chart is here: https://cdn.automationdirect.com/static/specs/driveselection.pdf
Old 12-14-2016, 05:08 AM
Buy a used drill press that has belts you can reconfigure to change the speeds and use that as a buffer motor.
JR
Old 12-14-2016, 05:42 AM
Guitar makers ( like me) use lower speed buffers with large diameter wheels (12" on mine). Grizzly tools has a good selection.
Old 12-14-2016, 06:34 AM
For the short term I modified my new technique to use the high RPM.
Just did a test of a quarter window vertical, polished and then anodized.
Pretty close to chrome so I'm happy overall, but would like the safety of the lower RPM.
Old 12-14-2016, 11:40 AM
I am limited to the size of the buffing wheels I use. A 12" one would be ideal but they are not available.
Old 12-14-2016, 11:41 AM
The Unsettler
I seem to recall you may have a handful of spare parts lying around.
Dig out some shafts and gears and build a transmission for it.
Use it in your marketing, "Polishing done by our one of a kind 915 Shinomatic"
"Brandon Won"
Old 12-14-2016, 11:46 AM
