-   -   Single gauge, able to monitor multiple things? (http://forums.pelicanparts.com/off-topic-discussions/939382-single-gauge-able-monitor-multiple-things.html)
Dansvan 12-15-2016 02:45 PM
Hello all. I've been searching for a smaller single size gauge that I can use to monitor multiple temps and pressures, to install in my 914. I understand it wold have to be digital and thats fine, just dont want to clutter up the dash with lots of gauges. I know on various sportbikes and ATV's you can scroll through the readings and select the one you want. Does anyone know of a system that can do this? Multiple sensors feeding a hidden brain, brain sending the input requested to the gauge? Thanks in advance.
Dantilla 12-15-2016 02:53 PM
The airplane guys have what you're looking for.
4-cylinder and 6-cylinder versions. Cylinder head temp, exhaust temp, oil temp, fuel flow, yada yada.....
Of course, probably more than you're looking for. Do you really need to know each cylinder's head temp? Do you want to run probes to every head and exhaust port?
https://www.jpinstruments.com/shop/edm-700/
Dansvan 12-15-2016 02:58 PM
No, I wasn't thinking EGT or CHT. More like coolant temp, oil temp, boost pressure, fuel pressure, Inlet air temp, oil pressure, wide band O2, etc. Just a unit that can receive inputs from various sensors and let you view them 1 or maybe 2 at a time as you wish.
WPOZZZ 12-15-2016 03:00 PM
I don't know if In Your Face Gauges is still around, but this is what they made.
http://forums.pelicanparts.com/uploa...1202357644.jpg
TimT 12-15-2016 03:00 PM
You can put together what you need using PLX devices gauge system
unclebilly 12-15-2016 05:09 PM
Aim dash! Andrew15 has one in his 914 race car and it is awesome and intuitive.
Or you could go with a Mychron 5 for go-karting.
