-   -   How to hang a mirror that says do not hang with wire (http://forums.pelicanparts.com/off-topic-discussions/939585-how-hang-mirror-says-do-not-hang-wire.html)
masraum 12-17-2016 02:05 PM
The missus bought a mirror that's designed to look like an old window, but it's a mirror. It came from Hobby Lobby, so I'm sure it's cheap chinese construction. It's very lightweight (about 19#) considering it's about 26" wide and 4.5' tall. The "frame" feels like wood, but if it is, it's very light. On the back there is a sticker that says "do not hang with wire".
OK, then what am I supposed to use to hang it.
It's something like this 2' x 4.5' and 19#. What I've got to work with is about 3" all of the way around the outside that seems like wood.
http://thumbs3.ebaystatic.com/d/l225...lS0w2-cpww.jpg
What are your thoughts.
If wire won't work, then I can't imagine why this would be any better.
http://www.allproducts.com/metal/uca..._hangers-l.jpg
Or do you think one of these would be better.
http://www.leevalley.com/en/images/i.../00s3430s1.jpg
http://www.sz-wholesaler.com/userimg...hanger-572.jpg
ossiblue 12-17-2016 02:47 PM
My guess is the frame is a dense foam-type material rather than wood and hanging with wire puts all the stress on a single anchor point--the screw-eye--and the stress is angular as the wire pulls toward the center line.
Looking at the picture, is there a cross member to the frame at the bottom of the arch? If so, that's where I would secure either the hangers in your first or second picture--across the horizontal member. All stress will be perpendicular to the anchor (nail or screw) with less likelihood of pulling out. If there is no cross member, then use the hangers in either the second or third picture, and mount them separately to the wall--could be a PITA to get level. You could also use a flat stock piece of aluminum running horizontally, secure it to each side, and mount the aluminum bar, level to the wall.
faverymi 12-17-2016 02:57 PM
Buy 2 3M sticky coat hangers or wall picture hanger put them in the back and attach a wire or rope.
masraum 12-17-2016 03:06 PM
Yeah, that's what I've been thinking. I was curious to see if anyone on the board thought the same.
There isn't anything at the bottom of the arch on the back. The mirror itself is the shape of the thing. The only place that's not mirror is a 3" rim around the perimeter. I like the idea of the flat stock. I could maybe even run 2 pieces up each side, and then mount another piece to those two, that way the whole thing would be attached at several points down each side.
thanks.
masraum 12-17-2016 03:07 PM
I'd wondered about that sticky stuff. That might work. I'll have to check the surface back there.
Noah930 12-17-2016 03:16 PM
I was going to suggest a French cleat, but it doesn't sound like there's any material to screw the cleat into.
I wouldn't do that 3M sticky stuff. I have never had one of those work. Eventually it falls off my wall/door, sometimes with nothing even hung on it. I certainly wouldn't trust a glass item with it.
Maybe a discrete little shelf at the bottom of the mirror to hold it up?
rwest 12-17-2016 03:24 PM
Steve,
How about those little mirror clips that you place around the outside- all sorts of styles, I was thinking of the clear plastic ones.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=Mirror+clips
Evans, Marv 12-17-2016 03:59 PM
If you want to hang it from the back side, maybe you could go to some place like H.D. and buy or get them to give you some of the large paint stir sticks. You could permanently glue two/three/four/??? on the back and attach your hardware to them to hang it by.
masraum 12-17-2016 04:26 PM
I'd wondered about that after one of the other posts. Maybe same AL right angle stock screwed to the wall and then to the bottom of the frame.
masraum 12-17-2016 04:27 PM
Originally Posted by rwest (Post 9400363)
Steve,
It won't work, because the frame around the mirror is 1.5" thick faux wood.
faverymi 12-17-2016 05:45 PM
It has worked for me.
Surface preparation?
Surface texture?
http://forums.pelicanparts.com/uploa...1482025492.jpg
David 12-17-2016 05:47 PM
French cleat would allow for several small screws every few inches to spread the load out
They sell them next to the picture wire at home depot
masraum 12-17-2016 06:53 PM
Surface texture?
I have had good luck with that stuff for several different purposes. I'll have to check the back where this would be sticking to see if it's a good surface for it.
Really? I didn't know that, but I have used them (came with some shelves from Pottery Barn and like them. I'll check that out.
MBAtarga 12-17-2016 07:08 PM
How about using a piece of real wood that you glue to the back side of the mirror itself - around the area of the arch bottom? Use mirror mastic glue. Then mount wire brackets to it - or actually cut the board for use as a french cleat (top section) itself. I would not trust the 3M products for something like this.
Hugh R 12-17-2016 10:01 PM
Don't hang it above the headboard of your bed!
Norm K 12-18-2016 07:15 AM
Looks like yet another use for JB Weld. A proper Sawtooth bracket combined with a couple of generous and well-placed dollops of the grey super-goo will have you (probably? ... maybe? ... have the broom standing by?) squared away in no time. ;)
_
javadog 12-19-2016 02:52 AM
Cut a thin piece of plywood the shape of the whole thing and glue it to the back. Anchor the wire mounts in the plywood.
JR
dad911 12-19-2016 07:37 AM
This. Home Depot sells, as does Amazon.
one half screws to wall, screw other half to frame, and hang. Easy-peazy.
1990C4S 12-19-2016 09:09 AM
I would hang it with wire and add two small nails along the bottom as rest points.
wildthing 12-19-2016 10:09 AM
I would use string if wire is not allowed.
David 12-19-2016 04:42 PM
To answer the why not just use wire question: on a recently purchased cheap frame, I installed tiny eye bolts and wire like I've done many times in the past and a few days later I found the picture on the ground when an eye bolt pulled out of the substandard particle board frame.
masraum 12-19-2016 06:23 PM
Yep, and I agree that this thing is probably not even actually wood, but some sort of foam. I just ordered a 30" cleat from Amazon. I'll have to connect it at either side of the frame. I may drill a couple of extra holes so I can use 2 screws on each side, and then hopefully, it'll line up so I can mount to 2 studs.
dad911 12-19-2016 06:29 PM
Originally Posted by masraum (Post 9402621)
.......and then hopefully, it'll line up so I can mount to 2 studs.
I use these anchors all the time, if I can't hit a stud. They screw into the drywall, never a failure.
http://forums.pelicanparts.com/uploa...1482200938.jpg
masraum 12-19-2016 06:56 PM
Yep, I have some and love them. They make a big hole, but are worth it.
MBAtarga 12-19-2016 07:09 PM
And about half the time when planning to use zipit fasteners - I end up locating at least 1 of them AT a stud!
masraum 12-20-2016 05:15 PM
You don't use the knock on the wall stud-finder test? Then if I'm close, I'll drill a tiny pilot to see if I strike wood.
dad911 12-20-2016 05:43 PM
Since we are talking studs, this is my favorite stud finder, use it almost daily. Basically a powerful magnet that sticks to the nail or screw: C.H. Hanson Magnetic Stud Finder-03040 - The Home Depot
