i'm putting a rifle back togther. extracting a broken bolt
when i fell, i sheared a fastener. i need to extract it.
are scope allen bolts hardened? this one was clearly loc tited..cuz despite that it is under zero tension i cant turn it. it's making me worried about the health of the actual rifle. hope i didnt bend something in the fall.
poof! gone |
Gon fix it with me hammer
try a reverse drill bit..
Rifles can take a hit, after all, they are designed to withstand repeated heavy pressures inside of them
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
The allen bolts are just regular hardness and can be drilled out with a regular bit or a left-handed bit. Since it looks like a ridge is on the top of the broken section I would recommend removing the bottom half of the mount and using a drill press with a sleeve around the bit as the bit will wobble. If you use a regular bit the broken piece will go all the way through. I am surprised a bolt, just one broke so maybe they are make of an annealed steel on purpose? Good luck.
I would just get new rings.
This right here, you'll be back in action in no time. Besides, you might be able to find a set cheap at the French Army Surplus (badum bish!)
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain Last edited by craigster59; 12-24-2016 at 03:09 PM.. |
I second the recommendation on the drill press. Once you get that off, I'd put a couple drops of PB Blaster or Kroil (or your favorite rusted bolt remover) and let that sit for a day, then repeat.
Banned
Double Trouble
this... but that looks like Leupold ring so about $25.00 the screws are soft and could be drilled out. However they are an 8-64 thread you won't find one of those at Lowes. Push to shove I'll look in my tool box junk at the shop if I have one i'll send it to you.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base Last edited by targa911S; 12-25-2016 at 06:30 AM.. |
Control Group
If it has blue loctite on it, wouldn't a bit of heat soften it up?
She was the kindest person I ever met |
The point about locktite is true as many scope screws are fastened with it. I forgot to mention if you do not have a Weaver Scope Mounting Kit I would very strongly suggest buying on. It has ring alignment tools, bubble levels, inch pound torque wrench and the various sized allen wrenches you might need. At the same time I would order a "gun screw set" and you'll have the needed replacement BUT since you have a set you'll NEVER break another one!
The rings are steel, they won't twist or bend that easy. There is enough meat on them to resist deformation. They took a hit and wanted to slide apart, the weakest bit broke, the screw. The rest is fine. Easy enough to check, if you put the 2 halves together, they will still fit. if not, replace em.
Not enough........ the two rings have to be in alignment with each other. I won't go into the details, but this is exactly why bedding a scope is done, especially when the rings are separate pieces.
just my opinion........... treat your firearms as you see fit. |
I don't see how you would twist the base of the scope rings, and not damage the top half.
Either way, it would be very obvious
Double Trouble
the front ring has a foot on it that twists into the base so it does in fact turn left to right. the rear one has a screw on either side holding it in place on the base. These screws can also be used to adjust windage. Bedding a scope is essential on rimfire guns.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
That scope was installed by a smith. He did align everything and bedded it. That's why I was hesitant to get new rings. Which I've decided to do. I'll let a gunsmith do it.
poof! gone |
Double Trouble
Whaaaaaat? Never heard of Leupold dove tail mounting system?
Double Trouble
It can be rebedded withou replacing, right?
