Question about differences between concrete stain and concrete stamp
Hi,
I am thinking about replacing my front yard driveway. Does anyone know/experience on good/bad or advantage/disadvantage between concrete stain and concrete stamp with colors? Thanks guys |
The stamp is permanent. The dye is only permanent if they put the dye in the concrete in the mixing truck. If they ad stain to the surface it wears off. You can have both dyed and stamped concrete. The disadvantage of stamped in my climate (Ohio) is that the surface holds water. The pockets of water freeze in the winter and thaw more slowly than water on a smooth surface. More insidious is if it's done poorly and the stamping is too deep water sits in it in the summer and grows mold, which is as slippery as ice when it gets wet.
I've done dye and it faded FAST!
Most of the concrete stamp & color work I have seen is done after the concrete is poured. They throw various colors (powder) on the fresh concrete and then tamp in the pattern using large rubber mats. Personally I don't think the color will hold up on a driveway. I had multiple neighbors who did stamped and colored walkways and they needed to be sealed every year or so - and still never looked as good as the first year after install.
Concrete stain (acid) is much more reliable but can tend to fade with heavy use. It can be applied on new or old concrete. I did a stain on my poured-in-place BBQ island top and then went over it with a clear coat. Looked amazing for years. |
Ever consider pavers ?
We had our driveway poured with colored ( came out if the truck done) slate grey and then stamped with a slate pattern. Finally sealed. Still looks great 5 years later. We have a freezing climate in winter and no problems yet.
In short, unless the color is added to the mix so the concrete itself is colored, it will fade and wear away. Stamping is a different issue as it puts a pattern into the wet pour--colored or not. Living in California, you probably won't have freeze or mold issues, but it's good to know about them. Stained concrete is really meant for interior uses, like counter tops and floors, that can be continually protected by sealants or coverings, like rugs. |
If you want a textured surface, stamping is the way to go. Mine has a granite texture, but you can choose from a lot of other patterns. I had mine done like JavaBrewer described with colored concrete (kind of a dark tan color). All the stained examples I've seen were flat concrete and faded after some time. I think it could be restained though. The stamped in color holds up well sheltered from the elements like on patios. The stamped in coloring on my driveway apron has weathered out a lot, but that's largely my fault, because I wasn't attentive as far as sealing it was concerned. I still like it though. Even the sheltered parts need resealing periodically. However it can be reconditioned by rolling it with MEK or some similar solvent periodically, since you don't want too much of a buildup of sealer. I like it a lot. No other place around here has anything like it.
I agree with what's been posted already but wanted to reinforce flyenby's post about considering pavers.
Interesting fact some may not be aware of....pavers are generally more durable than concrete. If you are just trying to 'dress up' your existing concrete driveway - and have no plans to replace it - that's a different story. I've also seen situations where the property owner replaced sections of their driveway over time.....to allow for budgeting considerations. It's not as efficient but doing things in phases sometimes makes sense. |
Thanks guys,
I like flagstone slate, but it is too expensive. They said that they can stamp the concrete almost like the flagstone pattern. The real flagstone cost more than double, almost triple the concrete price. On color the concrete from the truck, it's cost an extra $1500 or so. For coloring only the surface (before color stamp), it's cost a lot less. I am considering stamp now, but not sure if I should spend for color concrete or just the surface. Thanks guys. |
http://forums.pelicanparts.com/uploa...1485795232.jpg |
Definitely go for the colored concrete. There are lots of colors to choose from. I'm assuming the extra $1,500 is for a lot of yards of concrete. I think I only paid a few bucks extra (maybe ten or fifteen) per yard for color when I did mine. That was about eight years ago.
For reference, this is a pic of the patio not long after it was done. JavaBrewer, that driveway is beautiful.
http://forums.pelicanparts.com/uploa...1485795888.JPG |
Thanks Evans,
$10-$15 per yard is like $3k for a small drive way, 1,000 sq feet. This is only concrete color. Color stamp is on top of that. Am I right? Yours looks beautiful. |
rnln. No, the cost per yard at the time was something like $120/yd., which included the color. You will have to go through the normal bid process with the contractors. If I remember correctly, my per s.f. cost was around $4.25 including the color & stamping. I talked to about four or five contractors & as typical the price varied a lot. The one I went with was the lowest, although lowest price wasn't the determining factor. Concrete is concrete, so if it has the right psi rating, the code or better amount of reinforcing, thickness, etc., for specs and all things equal then price is what you look at. At the time, the total s.f. was right at 2,400 and the total cost was somewhere around $9,400.
stomachmonkey, that is right. Thanks.
Evans, I said $10-$15 per yard is only for concrete color per you said above. wow. The lowest I got for concrete alone is $6.5/sqft, 4.5" thick (1.5" rebar, 24" center). Include colors and stamp is $9/sqft. I want 6" now, let see. I just did a portion on the backyard, $6/sqft no color no stamp, 3" thick. Do you still have info on who you get it from? You did it recently right? Do you have pics of your front driveway? |
$6.50/ft seems pretty high to me. That include breaking up and removing an existing driveway?
BTW, you don't need 1.5" rebar, .5" thick is plenty. I usually space mine at 12", some might go 18". Never used 24." JR |
sorry, .5" rebar
This guy didn't mention demo. Someone else mentioned demo is $1/sqft. Let say demo is $1, then it's still $8/sqft include color stamp |
That's too much money. But then, I don't live in California. For a 1,000/sq-ft slab at 4.5" thick, the cost of the materials should be less than $2,500. That leaves $4k for a crew of 4, for a day.
That's a bunch, as 4 guys can get that done easily in a day, if they are not having to start by removing another slab or do any serious grading and compaction. JR |
I don't remember the exact added cost for color. In the back of my mind, it was something like $6 or $8 per yard, but the total cost per yard was around $120 at the time. This was eight years ago. I can take a picture of the front garage apron where the stamped coloring (powder) has weathered out in contrast to where it hasn't if you want. Again it's my fault for not keeping up on sealing especially that area, since it's the most exposed to the weather. Mine was new, 4 in. thick construction so if you are having to demo your area, you should expect an added cost. A buck a foot seems very reasonable to me. You will have to rely on the current rate for concrete in your area. The contractor will know where he wants to get it as part of his price.
Marv's picture of his patio brings up another thing to consider.
If you're going with stamped to mimic flagstone, having the color mixed into the concrete will give you a solid color finish with no variations--something not found in natural stone. However, adding the color powder to the already poured concrete, before the stamping, will give you the irregular color tones throughout the driveway, like in Marv's patio. That irregularity, along with the stamping, may be a more authentic look that you'd like. Of course, you now are in the wear away, fade, category. And yes, Marv your patio looks really great! |
http://forums.pelicanparts.com/uploa...1485814738.jpg
This is a shot of my deck, with the color mixed into the concrete in the truck. The variations in color are due to the sealer bringing the color to the surface in the low areas. http://forums.pelicanparts.com/uploa...1485814738.jpg This is the 'crete that had stain added to the surface. http://forums.pelicanparts.com/uploa...1485814738.jpg These two slabs were about the same color when poured. The gray one was stained on the surface, the colored on has the color mixed in the concrete. |
Yes, you understand the process right. The loose powder is washed after the stamping process. The powder embedded into the concrete remains giving the stamping the color and varied tone. Then sealer is applied over it. If you buy colored concrete for $15 extra per yard, that works out to about 7.75 cents per square foot extra. Not a significant expense compared to $6.50 per s.f. or whatever price you're being quoted. There is no way I'd go for applying a colored top layer to the concrete - if I understand what you said correctly.
I have stamped concrete all around the pool area and back patio. About every other year I hafts break out a new $17 hudson sprayer and a couple gallons of sealer and spray it down real good but it looks great.
But we don't have ice or moss or any of that other stuff to mess with. And we don't drive on it. |
