-   -   TV Projector for outside use (http://forums.pelicanparts.com/off-topic-discussions/944423-tv-projector-outside-use.html)
DRONE 01-31-2017 04:27 PM
Looking for something that me and the Mrs. can watch while out in the hot tub.
Not sure if we have to run the cable out to it or would have to set up a laptop up and run it over some sort of Wi Fi connection?
what do you have?
LWJ 01-31-2017 07:01 PM
Used a standard business type projector off a laptop for summer movie nights. $40 used off Craigslist. Big hit!
DRONE 02-01-2017 09:49 AM
Would I have to play CD's or would I have to sign up to ROKU?
rcecale 02-01-2017 09:56 AM
If you have Comcast, you may be able to stream right to your laptop, ostensibly, to your projector.
Not endorsing Comcast, just the feature...
Randy
Baz 02-01-2017 09:57 AM
Can you post an example of this, please? Perhaps a link to a CL ad? TIA!
rcecale 02-01-2017 10:18 AM
Here's one up here in Atlanta...
HDMI Projector
Randy
scottmandue 02-01-2017 11:02 AM
Most newer laptops have a DVD player, yes?
Baz 02-01-2017 11:09 AM
HDMI Projector
Randy
Thanks Randy!
So this is hooked up to any kind of device that contains a movie file and projects it onto a larger surface, I take it?
I have a very small DVD player, for example - so this would connect to the outputs of that device and project the DVD onto a wall or large screen vs. going through a conventional TV or computer monitor, right?
That would be cool if the quality of the video wasn't too compromised.
I have quite a few vintage surf movies on both DVD and VHS that i would love to watch outside on a larger medium.......
You can see my small DVD player on top of my TV in the bottom two photos....it plays International as well as US DVDs...which is good because some of mine are International only. Those pics were taken back in '04 before i upgraded to a flat screen.
http://forums.pelicanparts.com/uploa...1485975924.jpg
Gogar 02-01-2017 11:14 AM
Imagine it as just another TV. Depending on the inputs, you can hook a portable DVD or a computer or your cable box to it and good to go!
One consideration is also audio, so you need to make accomodations for that.
At Ms. Gogars we had a 'business projector' as mentioned and a set of cheapo multimedia speakers next to the projector. The projector had an HDMI input so I bought a HDMI 'pass through' box that seperated the audio out into a L/R RCA jack to the speakers.
It's fun! These small-format projectors aren't usually very bright so you need to turn off your porch light or something. You could find a really bright one but it'll cost you.
flipper35 02-01-2017 11:20 AM
2800 lumens on Newegg, refurbed with factory warranty was $167.
Baz 02-01-2017 11:24 AM
Thanks for the additional info, guys.....worth looking into!
I design and install landscape lighting and the concept of enjoying your outdoor living area after sun down is very appealing. Something like this is right in the same vein....
DRONE 02-01-2017 12:13 PM
Found a couple of projectors around here for $250/$300 on Craig's list, might have to look at Newegg, now I have to start thinking about a stand and a quick way to set up and take down
Baz 02-01-2017 05:50 PM
Lot of reviews on YT.....here's one but there are many more....
<iframe width="853" height="480" src="https://www.youtube.com/embed/NXZmrOmbfWY" frameborder="0" allowfullscreen></iframe>
crustychief 02-01-2017 07:29 PM
We have a sony hdmi projector and surround sound system we use in the desert. hang a white sheet on the trailer, build a fire enjoy.
LWJ 02-02-2017 05:17 AM
You got it. We bought an outdoor screen off Amazon. Push music through a bass amp. We host a big summer event and projected movies at night. Quality is fine.
You could use something much cheaper than a legit screen. Plywood. Sheet. Lots of reflective stuff will work. It doesn't need to break the bank.
This is fun stuff. Surf movies outside? Sigh me up!
DRONE 02-02-2017 06:16 AM
Crusty do you have any pictures of your setup?
dad911 02-02-2017 06:48 AM
I have a hot tub also. Think I would prefer a flatscreen smart tv, near the tub. Then stream wireless.
rcecale 02-02-2017 06:52 AM
Originally Posted by Baz (Post 9456371)
Thanks Randy!
Yes, just match the outputs of your player to the inputs on the projector. It works just like hooking it to a TV or computer monitor.
There are steps you can take to improve the quality of the output. Mainly, project it onto an actual screen. I've seen folks try a setup where they hang a white bedsheet. It works, but not exceptionally.
You can actually purchase paint that has a bit of reflectivity mixed into it, so you could find a large, flat surface and then paint it. This would alleviate the need for a screen...
Randy
stealthn 02-02-2017 05:29 PM
Did you have a budget?
https://www.youtube.com/watch?v=5PmwDbkaeJs
