What are the best air hose couplers?
I have purchased air hose couplers from several different places. From the cheap ones to the somewhat expensive ones I have yet to find one that does not leak when connected. Does anyone here have any advice on where to get quality couplers that do not leak after the first use?
89 930 Cab Black 11 Cayenne |
Milton M type
I've had good luck with Milton M type connectors. Always install a brass female quick-disconnect and usually use steel male pieces. What type of leakage issues are you having?
David Gray 71 Gemini Blue Metallic 911T |
To answer your question NO
Hissing air hose fittings
Rick 88 Cab |
Platinum Member
I've found the harbor freights to be similar to other brands. I always keep a few spares on hand.
Yep, I just use the same Milton connectors as mentioned above. Pipe thread tape when I install them . They do wear out and leak eventually, but I usually get a few years out of each one . When mine do start hissing ,I toss em.
Same as above, Brass female coupler , and steel male end .
No left turn un stoned |
"Brass female coupler , and steel male end ."
~~~~~~~~~~ Why this combo?
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
Fitting post, mine started leaking today....
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
Thanks for the replies
Brew Master
Another vote for Milton here. It's all I use in my shop.
Milton hiflow is the bomb but the harbor freight copies are ok for home use
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I've dated a few who probably had brass couplers.....just sayin'.....
Old dog....new tricks..... |
In the meantime, just reverse your old washer.
We use Staubli connectors, but then again, we are using master-slave manipulators to connect them.
![]() Nuclear connection solutions for remote handlingÂ*-Â*Stäubli
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
