question on welding aluminum
Hi guys,
I upgraded my lincoln weld pak 100 to weld aluminum with 100% argon. The first problem I encountered was every time I hit it, I got a bird net right at the wheel. If I pull the trigger but the wire is not touching the aluminum (not sparkling), then wire ran out fine. I tried more than 5 times and had the same problem. Anyone know why? Thank you. Here is how I set it at.
Fat butt 911, 1987 |
Banned
AC or DC?
abit off center
When holding the gun you feel the wire hitting? is it kicking back? Could have the feed speed up too high or not enough amps. You using a spool gun?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Assuming you don't have a spool gun...
Do you have a Teflon liner in your gun? If not, get one. A push-pull gun is the right way. Anything else is a struggle.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Make sure tip you are using is bigger than the wire. Tim
Inside the welder; the earth and positive, are they setup correctly for aluminium? And the wire diameter correct for the tip.
see www.lyallbaybeach.co.nz |
unsafe at any speed
I have a Lincoln SP135T... I tried converting... Put the teflon liner in the hose... Special rubber wheel for the drive... Even added some plastic tubing to try and stop it from bird nesting.. No luck. Aluminum wire doesn't like to be pushed that far. Get a spool gun.
I bought some Neptune stick welding rods made for aluminum, and use my Miller portable DC welder with reversed polarity for welding aluminum.
Bill Swartzwelder 2002 R1100S Prep/2006 BMW R1200GS 1969 BSA StarFire |
^Agree, aluminum wire doesn't do very well in longer runs. Spool gun might be the answer. Tim
Guys, he has not even struck an arc, he can't feed wire without getting a birdsnest. The problem is not polarity. Yet.
Unregistered
He said the aluminium wire feeds just fine until he strikes an arc. Then it makes a birds nest. Sounds like the power from the arc is getting to the wire feed motor and causing it to go ape ****. |
So when he says he 'hit it' he means the wire hit the weld material? I assumed he meant the trigger?
If that's the case he does need to confirm the polarity AND the weld start characteristics, which he may have no control over on that machine. But first you need to make sure the power source is turning on. If you are hitting the material with the wire and there is no arc, then either the power source is not on, your wire has come off the feed head, or you don't have a ground. It should be slightly difficult the hold the wire back with two pinched fingers while you're feeding....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 02-16-2017 at 03:30 PM.. |
I felt just a little bit, close to none, compare to the kick back when welding with flux wire. I will try to slow the wire speed down, after I see if I can pull the wire out. Now, it's stay in there. The aluminum wire is easy to break when pulling it.
timchar, the tip's hole is bigger than the wire. It's can run out easy when not welding. Bill Douglas, I think it's is correct, according to the diagram. Switching + and _ wires. install the module for gas. Checked on gas coming out at the nose when I pull trigger, flip the wheel.
Sorry I didn't make clear. I could get wire to come out smoothly when I pull the trigger. I can feel gas comes out to. The bird net is right when I strike it. Soon it arc, it's stop, and bird net.
Nope. I saw a regular Lincoln - without spool gun, successfully welding with aluminium on a youtube. I remember the guy said to keep the cable reasonably straight and it will feed OK.
here is how the wires set up. I think it is correct. + goes to the gun. - goes to the clamp for -
Looking at the 2 knobs, I did set wire speed to high and low power, as many youtube clips mentioned.
Tig it!
85 928S; LSx conversion, 5 speed with LSD. ![]() ![]() IRR... What IRR! ![]() |
Thread Tools | |
Rate This Thread | |
