4 post lift!! Finally!! Install thread
Well finally made a lift purchase. Plan is porsche on top and trans am on bottom. Primarilyfor storage purposes but also maintenance as well. I thought I would post a thread to share my journey.
Last night I raised my garage door up for needed clearance for the front of the Porsche to tuck under it while door is open. Easy modification of the railway took care of this. Made 3 relief cuts on both sides and bent and welded to achieve the desired angle for more clearance. Had to ad half turn to tension springs a little more and the door was balanced. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by JoshCole1122; 03-07-2017 at 06:22 AM.. |
I had more straight actions added to bring it closer to the ceiling in order to retain the original bend......
What lift did you buy? I'm about to pull the trigger on a BendPak 4 post.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I will be looking at buying one too in the next 6-9 months.
One thing I need to remember is to verify distance between ramps so I can drop the engine through the ramps., or rather lift the car off the engine.
Neil '73 911S targa |
There are ways to do it, I've searched. Jack tray provides options as well.
Dropping between the ramps is easiest, but you could back the car all the way to the end and pull the engine and trans out over the crossbeam or drop them a little bit, unbolt the trans, rotate the engine 90 degrees and then lower between the ramps.
I'm planning on a 4 poster as well. Would rather have a two post but trying to anchor it in my radiant heated floor poses a problem. Wish I had mapped out my Pex tubing before the floor was poured. I'm not feeling lucky.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Check out the group buy thread on Garage Journal if you haven't. You can request a quote from a user there that is affiliated with the company or dealer (dont' recall which.)
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Hey Pete, you've got a pretty good idea of where your tubing is based on that picture. Just find out what size the grid work is that it's laying on (rebar mesh?) and count the squares.
Scott '78 SC mit Sportomatic - Sold |
Platinum Member
^^ Run hot water through the lines, and an IR camera. I'd think even a gun type IR thermometer can find the hot spots.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
If your floor is smooth, you can actually move the lift around with a car on it. Casters on..raise car just until the casters pivot the lift up...the whole thing can be pushed around by one person.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Can't find that thread, can you share a link? Thanks!
Awesome! I'm excited, lift should arrive this Thursda.y.
I made the mistake of doing a search on lift recommendations last night. Every time I do, I end up more confused than when I started. Almost as bad as, "What oil should I use?"
Josh,
How tall are your ceilings? about to pull the trigger - Anyone have experience with a Directlift? Any experience good or bad on american made vs. overseas? |
Yes it is very confusing finding the right lift. You have to take everything in consideration. My ceilings are only 9' 7" tall. Trans am and Porsche stacked. Both those cars roughly 50-52" tall. Rams are 4 in thick. Need to determine locking positions etc. measure about 100 times.
Sent from my iPhone using Tapatalk |
You will have no prob with that height. My ceiling is about 3" taller (9' 10) and have that much or more to spare with both cars stacked.
The first time you raise the top car to the ceiling..mark the lift post so that you don't go over that ever! The locks will require that you go beyond the height you want by an inch or so.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 03-07-2017 at 10:43 AM.. |
