4 post lift!! Finally!! Install thread
Well finally made a lift purchase. Plan is porsche on top and trans am on bottom. Primarilyfor storage purposes but also maintenance as well. I thought I would post a thread to share my journey.
Last night I raised my garage door up for needed clearance for the front of the Porsche to tuck under it while door is open. Easy modification of the railway took care of this. Made 3 relief cuts on both sides and bent and welded to achieve the desired angle for more clearance.
Had to ad half turn to tension springs a little more and the door was balanced.
Old 03-06-2017, 06:20 AM
I had more straight actions added to bring it closer to the ceiling in order to retain the original bend......
Old 03-06-2017, 07:02 AM
I could have done that but then would have had to raise my spring and get longer cables. That would have been the more ideal way to do it though!
Old 03-06-2017, 07:21 AM
Don Plumley's Avatar
What lift did you buy? I'm about to pull the trigger on a BendPak 4 post.
Don Plumley
M235i
Old 03-06-2017, 07:31 AM
"Auto lift" 8000 lbs. capacity. Included jack tray, drip pans, casters, and ramps.
Old 03-06-2017, 07:36 AM
I will be looking at buying one too in the next 6-9 months.
One thing I need to remember is to verify distance between ramps so I can drop the engine through the ramps., or rather lift the car off the engine.
Neil
'73 911S targa
Old 03-06-2017, 09:22 AM
There are ways to do it, I've searched. Jack tray provides options as well.
Old 03-06-2017, 10:01 AM
froggert's Avatar
Dropping between the ramps is easiest, but you could back the car all the way to the end and pull the engine and trans out over the crossbeam or drop them a little bit, unbolt the trans, rotate the engine 90 degrees and then lower between the ramps.
Old 03-06-2017, 11:02 AM
pete3799's Avatar
I'm planning on a 4 poster as well. Would rather have a two post but trying to anchor it in my radiant heated floor poses a problem. Wish I had mapped out my Pex tubing before the floor was poured. I'm not feeling lucky.
Pete
79 911SC RoW
Old 03-06-2017, 11:10 AM
MBAtarga's Avatar
Check out the group buy thread on Garage Journal if you haven't. You can request a quote from a user there that is affiliated with the company or dealer (dont' recall which.)
Mark
'83 SC Targa - since 5/5/2001
Old 03-06-2017, 11:49 AM
Hey Pete, you've got a pretty good idea of where your tubing is based on that picture. Just find out what size the grid work is that it's laying on (rebar mesh?) and count the squares.
Scott
'78 SC mit Sportomatic - Sold
Old 03-06-2017, 01:32 PM
Platinum Member
dad911's Avatar
^^ Run hot water through the lines, and an IR camera. I'd think even a gun type IR thermometer can find the hot spots.
Old 03-06-2017, 06:37 PM
I have the same lift...you will really like it.
If your floor is smooth, you can actually move the lift around with a car on it.
Casters on..raise car just until the casters pivot the lift up...the whole thing can be pushed around by one person.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-06-2017, 06:56 PM
Can't find that thread, can you share a link? Thanks!
Don Plumley
M235i
Old 03-06-2017, 07:08 PM
Awesome! I'm excited, lift should arrive this Thursda.y.
Old 03-07-2017, 03:27 AM
MBAtarga's Avatar
BendPak 4 Post / 2 Post Lift Group Buy - The Garage Journal Board
PM userid Mystic195
Mark
Old 03-07-2017, 03:28 AM
Thanks!
I made the mistake of doing a search on lift recommendations last night. Every time I do, I end up more confused than when I started. Almost as bad as, "What oil should I use?"
Don Plumley
M235i
Old 03-07-2017, 07:24 AM
Josh,
How tall are your ceilings?
about to pull the trigger - Anyone have experience with a Directlift?
Any experience good or bad on american made vs. overseas?
Old 03-07-2017, 09:10 AM
Yes it is very confusing finding the right lift. You have to take everything in consideration. My ceilings are only 9' 7" tall. Trans am and Porsche stacked. Both those cars roughly 50-52" tall. Rams are 4 in thick. Need to determine locking positions etc. measure about 100 times.
Old 03-07-2017, 10:18 AM
You will have no prob with that height. My ceiling is about 3" taller (9' 10) and have that much or more to spare with both cars stacked.
The first time you raise the top car to the ceiling..mark the lift post so that you don't go over that ever! The locks will require that you go beyond the height you want by an inch or so.
98 Honda Prelude
22 Honda Civic SI
Old 03-07-2017, 10:40 AM
