Detached Member
Shower Leak thoughts?
One of the two shower heads is dripping a lot. 15 years ago or so, I installed a his and hers shower heads and controllers with separate controllers. One side is dripping out of the shower head constantly. It has its own volume control (on and off) (left image) and temperature control (right image), its a Delta system and the Beauty plate says "2300 series) don't know if that is the system or the beauty plate series. Can't find the installation paperwork.
Since its dripping at the shower head, I'm guessing its the left volume control valve. Went to HD and two local plumbing supplies and they said bring in the cartridge to match it up, the trouble is I saw nothing in their inventory that remotely looked like what I had. So I have to shut the water off to the house and go and see what I can find. Any thought?
Hugh Last edited by Hugh R; 03-14-2017 at 08:11 PM.. |
Yes, that's the best way. Forget HD, they wouldn't have it. Get it to Fergunson and talk to the guys behind the counter. They should be able to able to get you the correct part. The Volume control is worn. Getting that part out is going to be a challenge sometimes due to age and some of the plastic parts.
Detached Member
![]() More better image. I need a newer digital camera. The holes are absolutely dry, which is good news.
Hugh Last edited by Hugh R; 03-14-2017 at 08:26 PM.. |
I have Kohler fixtures...the vavle in my master bath went bad..I contacted Kohler and they sent replacement parts for free..maybe contact delta and see..know one will know the product better then the manufacturer..also kohler is warrantied for life..maybe delta offers the same..Steve
Detached Member
Teflon taped them up 15 years ago, and the hard water here is still killing it. Excellent idea on the warranty stuff, I'll check it out first, Not a big deal, I still have a second shower head and two more showers, just an annoyance. The wifey likes two shower heads, so she isn't happy....you know what they say about Momma, "she isn't happy, no one is happy".
Hugh Last edited by Hugh R; 03-14-2017 at 08:25 PM.. |
My bad valve was also do to hard water...it's a killer..good luck..
I had a shower fitting (brazed) start to leak after 25 years or so of southern CA bad water. I had already installed a whole house softener but the corrosion had already started. I tried working through a hole like yours and it was a tad hard so I made an access panel of the same materials as the shower. That made working on things much easier for sure. You might want to consider that and also a softener since you live in southern CA too?
I was afraid to open this thread...skeered that Higgins was at it again
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
My Delta kitchen faucet was recently struggling to find the sweet spot to make the water stop. I sent Delta an email with my model of faucet and the part number I needed. The part showed up a week later for free.
Randy '87 911 Targa '17 Macan GTS |
Couple thoughts...
If hard water deposits are keeping the rubber bits from sealing, those can be cleaned off by soaking them in something like CLR. If you end up replacing parts, do both of them now. JR |
Detached Member
good idea on the CLR. I'll try that first.
Hugh |
