Outlite A100, uses either a single 18650 rechargeable cell or your can use the AAA adapter.
https://www.amazon.com/Handheld-Flashlight-Rechargeable-Included-Adjustable/dp/B00VZT2WP6/ref=sr_1_2?s=instant-video&ie=UTF8&qid=1490041075&sr=8-2&keywords=rechargeable+flashlight |
I have had batteries leak in all kinds of devices. A gas powered r/c aircraft, radios, and yes flash lights too. I use a quick fix should a toxic melt down occur, I clean it off with wd-40 and steel wool, even medium grit sand paper can help out in a pinch. Now I know better.http://forums.pelicanparts.com/uploa...1490069336.jpg
The lithium ion batteries do not use acid for the electrolyte.
Eneloop rechargeables instead of crappy alkaline single use batteries. These are good for up to 2100 charge cycles and I have never seen one fail and damage a light or appliance.
https://www.thebatterysupplier.com/products/newest-version-panasonic-eneloop-4rd-generation-16-pack-aa-nimh-pre-charged-rechargeable-batteries-free-battery-holder-rechargeable-2100-times.html?gclid=CLWQuaKB6NICFYlrfgodDWQIqg |
Eneloop are NiMH, which have a lot lower capacity than Alkaline, or Lithium rechargeable batteries. The electrolyte is NaOH, so if they rupture, they will cause corrosion.
Battery Myths vs Battery Facts |
Put a condom on them. Make sure it's the thin type.
My dad once told me if you want a flashlight to last never leave batteries in it. He would tape them to the outside in a plastic bag where if they did leak it wasn't a problem.
| All times are GMT -8. The time now is 10:32 PM. |
