what is a good strategy to bolt down a gun safe?
i can drill and epoxy in some studs..but the thought of moving a safe up and over some extended bolts does not seem like a fun way to spend a day.
i was thinking of emptying it, drilling down from the safe floor and use some concrete lag bolts..contractors call them red-heads or something. i dont think tapcon makes a big/long enough conc screw or i would just do that.
poof! gone |
I did mine just the way you said. Drill through the bottom of the safe and use Redheads.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
My safe came with predrilled holes in the bottom, but I didn't use them initially...not worried sbout it being stolen. But the damn thing wanted to tilt forward when the door was open at a certain angle so it's bolted to the floor now
.I didn't use lag bolts....just regular bolts that I put nuts on from my crawl space... |
It wasn't a gun safe, but I have bolted down a safe before. It came with a bolt and anchor and was predrilled on the bottom. What I did was mark the holes, move the safe, drill the holes, move it back, then bolt down. I would think you might have to do the same since I wouldn't think you could get the anchors through the hole in the bottom of the safe or they would be too small.
To answer the question, I would use bolts.
![]() You might swing by a safe store and talk to them. See if they have any solutions.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Just fill it with enough guns & ammo that it is too heavy to move.
Bunch of old cars
My cheap safe came with anchor holes set up already. Should I ever get around to putting it the back of our walkin closet Ill anchor it. Until then ....
oh..mine already has a few holes in the bottom. the floor is thick! i'd need hardward with some reach.
poof! gone |
Tapcons are worthless for this. A prybar would pull them out.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Ours came with the anchors and extra putty for the fire rating. They are or are similar to the Red Head Trubolt anchors.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Now in 993 land ...
As mentioned, you use bolts and put anchors into the concrete. I blessed a rental home once with a couple. Now in a raised foundation home it is into 1" wood subfloor and 2x4 studs.
I'd like to get a bigger one ... G |
Gon fix it with me hammer
This.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Use a wedge anchor. Get on McMaster Carr's web site and specify the length you need and order accordingly. If you want to do it in one step without moving the safe, buy some washers so you can enlarge the holes in the safe bottom big enough to insert the anchors through the holes.
Make sure you get the holes really cleaned out before inserting the anchors. JR |
Just returned from my sons home. He has 2 gun safes.
Your answer is to buy such a large safe, as his, that couldn't be moved by 2 or 3 strong men. His are such that they will not be moved, unless professionally. Buy Big. |
I have one.... . But if a pro wants the contents....it's all over but the insurance settlement...YMMV.
Rutager West 1977 911S Targa Chocolate Brown |
If you just want it 'bolted' use tapcons. There are some pretty large tapcons available now.
If you want it held securely wedge anchors or fiber anchors are good. Chemical anchors are probably strongest.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Slackerous Maximus
It really about slowing people down. I really should bolt mine down, but I know for a fact that the slab is only 4 inches of concrete, with no rebar. Sledge hammer could break away the concrete around the safe in short order.
2022 Royal Enfield Interceptor. 2012 Harley Davidson Road King 2014 Triumph Bonneville T100. 2014 Cayman S, PDK. Mercedes E350 family truckster. |
i just kinda want to stop the meth addict knuckleheads..
my luck they try to tip the thing over and it falls on them and they sue my ass. i just want to keep it down so they cant scooch it up so they cant wedge a dollie underneath. i can get into a safe and i am no safe cracker..i would use a portable bandsaw and cut off the hinge side/corner.
poof! gone |
