-   -   Home water systems experts - advice needed please (http://forums.pelicanparts.com/off-topic-discussions/953744-home-water-systems-experts-advice-needed-please.html)
wdfifteen 04-18-2017 01:03 PM
My neighbor's water well "collapsed" according to their plumber. The water they get is full of air, muddy, and pressure is almost non-existent.
My garage is about 100 feet from a sill bib on their house. Can I (or should I) run a garden hose from my system to the sill bib so they can have minimal water, for toilet flushing,etc? I figure if I close the gate valve at the exit from their pressure tank, then their house plumbing will just be an extension of mine. Is there something here I'm not seeing, or will this scheme work?
Neighbors have 3 kids with another on in the way in 2 months. They are kind of desperate. Mrs WD and I took them a 5 gallon jug of drinking water, but they need more.
Hugh R 04-18-2017 01:07 PM
I guess it would work, I'd consider putting in a vacuum break at your house, like you may have if you have an in-ground sprinkler system.
74-911 04-18-2017 01:09 PM
I did the exact thing for my neighbor a couple of years ago when his well collapsed. Just need to use the largest diameter hose you have. We just closed the valve at his pressure tank, hooked up the hose to the bibs at his/my house and turned on both faucets. He used this for 2-3 days with no problems.
Gogar 04-18-2017 01:23 PM
+1 just buy a "hose thread backflow preventer" at HD and you should be fine
Cajundaddy 04-18-2017 04:24 PM
^^ This and you are good to go.
Evans, Marv 04-18-2017 04:29 PM
If they are going to have to have the well cleaned out and maybe drilled down farther, it may be a good idea for them to have a gravel sleeve put in when they do that.
HardDrive 04-18-2017 05:33 PM
Only thing is that the new hose bibs have back flow preventers. Not sure his house will let the water in...
carambola 04-18-2017 05:53 PM
a noble gesture,
doable but communication will be key.
arrange shower/washing times.
as everyone else has stated, don't contaminate your own source.
you will make a friend for life
wdfifteen 04-18-2017 08:28 PM
Thanks. That's something to consider. The house is 25 years old. I don't know if back flow preventers were code back then. Something to check out.
FPB111 04-19-2017 06:51 AM
We did this for our neighbor when their water main turned into a fountain in the front yard. It worked for for both houses. We did coordinate showering but even that wasn't much of a problem. You just got reduced pressure
wdfifteen 04-19-2017 09:54 PM
The verdict on their well is that it is junk. It is only 40 feet deep. The rest of the wells in our area are 80. It will take two weeks to get a driller out here to drill it down deeper. So, they are all hooked up to my system. Got a back flow preventer and made the final connection with a washing machine hose. That hose with it's little 3/8 ID isn't going to let them use enough water to stress my system, and I don't hear my pump running much, so I think we're good to go for the next two weeks.
Thank you all for the advice.
Took them a big pot of pasole yesterday and I'm making a massive Manfood Casserole for them tomorrow. I forgot how much food three kids can go through.
MBAtarga 04-20-2017 07:11 AM
WD - that's being a great neighbor!
Porchdog 04-20-2017 07:58 AM
So long as there is a check between their pressure tank and well (or their pump check/foot valve is still working) they should be able to still use their pressure tank. You may want to recalibrate air pressure to match your pump. Then they will have a more or less normal flow in their home. That should minimize flow demand through the hose, as it will just balance pressure.
My Dad and his best friend build lake houses side by side in the 60's. Their place was supplied by our well through a 1/2" copper pipe for decades with no issues.
unclebilly 04-20-2017 08:11 AM
Just make sure you don't run your well dry. Otherwise, go ahead.
unclebilly 04-20-2017 08:12 AM
And kudos for being a great neighbor.
wdfifteen 04-20-2017 04:12 PM
Their pump is laying out on their lawn and the valve between their pressure tank and the rest of their house is closed, so everything south of that valve is cut out.
cabmandone 04-20-2017 04:57 PM
Hard to do without chlorinating your well the way you're going about this but I'd suggest they chlorinate their lines and tank just in case any contaminants got in their lines. Wouldn't want the kids or 7 months pregnant wife getting sick from contaminated lines.
You could probably shutdown your home from the system, add chlorine to the well and then pump the chlorinated water to their home and through the lines (bypass any softener) and once the chlorine dissipates reopen your home lines.
