Globe and Mail iceberg photo
In todays paper, iceberg alley near St. John's NFLD
Old 04-19-2017, 02:35 PM
Old 04-19-2017, 02:39 PM
Home of the Whopper
That's sooo cool!!
Thanks for sharing!!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 04-19-2017, 02:42 PM
least common denominator
scottmandue's Avatar
We're going to need a bigger ice pick!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-19-2017, 04:06 PM
Jolly Amaranto's Avatar
Wow, there must be a huge amount of ice still underwater. Must be pretty deep there.
Old 04-19-2017, 04:36 PM
wdfifteen's Avatar
You see some amazing things up there. Thank you for all your posts.
Old 04-19-2017, 05:02 PM
I just read about that and saw the pics yesterday on the BBC website. Pretty amazing. That thing looks like it's a few hundred feet tall. Yeah, it would be interesting to know how big it was under the water.
Old 04-20-2017, 05:10 AM
As a side note, that village picture is typical of the roads used during Targa Newfoundland held every September.
Old 04-20-2017, 05:20 AM
MBAtarga's Avatar
Only about 13% of the iceberg is above water.
Source:
https://www.navcen.uscg.gov/?pageName=iipHowMuchOfAnIcebergIsBelowTheWater
About 7/8ths of an iceberg is below the water line. This figure is approximate. Although icebergs are similar, not all are the same. Varying factors are iceberg density, water density etc. Keep in mind we are talking about an iceberg's mass. Due to irregular iceberg shapes, icebergs may have varying heights out of the water, but mass is relatively consistent. The following provides further background information:
Buoyancy
Buoyancy is the upward force exerted on an object immersed in a fluid. Of course, water is the most common fluid, but buoyancy also applies to hot air balloons (where the fluid is the surrounding air) and many other situations. What's the basic idea?
Archimedes figured out that the key to buoyancy is how much volume the object displaces compared to its weight. Archimedes Principle of buoyancy states that the upward force on an object in a fluid is equal to the weight of the fluid that is displaced. If this bouyant force is less than the weight of the object itself, the object will be left with a net downward force and will sink. If the object floats, it floats enough that the bouyant force exactly balances its weight.
For solid, uniform objects like an iceberg, this boils down to the object's mass density, its mass divided by its volume, usually represented by the Greek letter . For something like a boat hull, which is hollow, not uniform, you have to just look at the total weight and the volume of displaced water.
Example: Icebergs
So let's take the case of the iceberg. Lets say it has mass Mi and volume Vi. Their ratio is given by the mass density of ice: M/V = Rhoi ~ 0.90 g/cm3 (iceberg ice is more dense than normal ice since it has been compressed by thousands of years of pressure - normal ice is 0.917 g/cm3). Since we already know it floats, lets say that the volume below the surface of the water is Vw. This is the volume of water displaced, and the buoyant force is equal to the weight of that displaced water, which has mass Mw = VwRhow. The mass density of liquid water was originally used to define the gram, so it has the convenient metric value = 1 g/cm3. Sea water on the other hand is more dense since it has salts, therefore we shall use Rhow = 1.035 g/cm3 (or 1035 kg/m3).
The weight of an object is given by its mass times the acceleration of gravity, g = 9.8 m/s2:
W = Mg
The iceberg has weight Wi = Mig and the buoyant force is equal to the weight of the displaced water, Ww = Mwg. Furthermore, since the iceberg is floating, its weight exactly balances the buoyant force:
Ww = Wi
Mwg = Mig
VwRhowg = ViRhoig
Vw = Rhoi/Rhow Vi
So, the fraction of ice underwater, Vw/Vi, is given by the ratio of densities Rhoi/Rhow=0.87. Over 87% of an iceberg's volume (and mass) is underwater. As you can see, the convenient definition of the gram gives us a quick way to see how much of a floating substance lies below the surface of fresh water: the fraction is equal to that substance's mass density in g/cm?.
Summary
Archimede's Principle of bouyancy states that the bouyant force on an object is equal to the weight of the fluid displaced by that object.
The underwater fraction of a substance floating on water is given by that substance's mass density in g/cm3.
Mark
'83 SC Targa - since 5/5/2001
Old 04-20-2017, 08:06 AM
Yikes!!
Old 04-20-2017, 08:57 AM
Are those telegraph or power lines?
Old 04-20-2017, 08:59 AM
Slackerous Maximus
HardDrive's Avatar
A lady at the local bed and breakfast was interviewed on NPR about it today. Listening to the host's question for her, I can understand why people think Americans are morons.
2014 Cayman S, PDK
Old 04-20-2017, 09:21 AM
check out what the weather channel is calling it! Prehistoric...A floating Mammoth!
https://weather.com/weather/today/l/CANF0953:1:CA
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-20-2017, 10:35 AM
83 911 Production Cab #10
JJ 911SC's Avatar
In the late 70's we sailed by one and fired a few 3.5" rounds on it, not much damage.
You can feel the cold air from it a mile away.
Who Will Live... Will See
Old 04-20-2017, 11:45 AM
CurtEgerer's Avatar
For sure. Very familiar looking from watching the Targa vids over the years.
2009 Targa Newfoundland Video
Old 04-20-2017, 12:12 PM
