Name that engine
Name of the game is to identify the make and model of the engine in the picture. It is a 4 cylinder flathead with dual ignition! Good luck.
http://forums.pelicanparts.com/uploa...1494791317.jpg |
1930's Plymouth?
Stutz Bearcat?
Early '20's Stutz. You can see the logo cast into the lifter cover under the front section of the intake manifold.
Prolly from a K series. |
Interesting t-head design. Is it a 4 valve engine?
Yep, 1921 Stutz Bearcat engine. It is a 4 cylinder, 360+ cubic inches, 4 valve per cylinder with twin ignition! Idle speed is under 100 rpms! Usually put behind a 3 speed manual transmission. This engine had an electric starter!! Good call Baz!
| All times are GMT -8. The time now is 11:14 PM. |
