(the shotguns)
If you pressure wash your deck you need this
Just used this thing on my deck with my pressure washer. Holy crap sooooo much quicker!
![]() Sent from my iPhone using Tapatalk
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Fleabit peanut monkey
What used to "grind my gears" is that one could pressure wash with devote diligence and still get light and dark streaks because of how you applied the wand.
None of this?
1981 911SC Targa |
Thanks for the link.
Don . "Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence." - - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View |
(the shotguns)
No but you have to be wary of stopping it in one spot. You can get a ring. Happened to me a few times but I think next go round I'll be able to avoid it. Sent from my iPhone using Tapatalk
Model Citizen
I have one of these, the problem I have with it is that the tube that connects to the P/W is short and I'm tall. It means I have to stoop the whole time I'm pressure washing. (It does do a pretty good job, though. Way better than just a jet from a wand....)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
What is it? Photo doesn't load for me.
'95 993 C4 Cabriolet Bunch of motorcycles |
Mine is fantastic. I wouldn't even try a deck anymore without it!
David 1972 911T/S MFI Survivor |
Several makes; hooks to the quick disconnect on your PW. About the diameter of an LP, a skirt all the way round, two PW jets are mounted on a spinning arm. The whole thing floats above the concrete like a hover craft floats.
You do not have permissi
Preconditioning is essential.
Wet down everything before getting to it. (I'll post another thread on power washing and staining.) We've had rather mild winters with more outside mildew recently in Michigan. Never seen it before. Everything around here gets "dirty" too quickly. Use "Wet n forget" on everything inorganic using a container sprayer and dilution directions 1:5. It seems to be a decent product for prevention. It needs a week of dry heat followup afterward to work best. It is mild for most plantings. Last edited by john70t; 06-20-2017 at 05:15 PM.. |
Oh yeah. I've got one of these and it does a number on my washed gravel surface concrete patio, sidewalk and driveway. Every now and then one of the jets will get clogged and you'll have to take it off and clear the clog. If it's not floating like a hovercraft then the wand isn't spinning, so sometimes you have to hand prop it to start the spinning motion. It's a tool well worth the price. 2 thumbs up from me.
Bollweevil
I have the Black and Decker model of the above... does a great job of cleaning heavily mildewed concrete driveways. No streaks and you can cover a lot of area in a hurry. only complaint (as herr oberst mentioned) is having to stoop over as the pressure washer wand is a bit short for taller persons.
Definitely worth the price of admission....
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
RETIRED
Hire someone short....do I need to think of everything?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I liked my sidewalk one so much, I found a smaller diameter one that just fits between the ribs on my metal roof. Cuts cleaning time around 60%.
I use one of these on my Simpson Water Blaster.
Works very well. ![]() https://www.google.com/#q=simpson+power+washer+floor+nozzles&tbm=shop&spd=7137453889531636324 |
