-   -   Question about Clear bra or cheapo alternative: (http://forums.pelicanparts.com/off-topic-discussions/962977-question-about-clear-bra-cheapo-alternative.html)
speeder 07-12-2017 08:26 AM
I may be riding a MC I bought 1000 miles through summer bugs and random flying gravel to get it home. I want to protect the paint on fairing but do not want clear bra permanently or semi-permanently installed, just for a few days.
Is there any similar adhesive film that would be thick enough to work as protection but fairly easy to remove w/o leaving a lot of adhesive behind? The answer to this could be great for any road trip or track day w any nice vehicle. I've seen people cover the whole front of a 911 w 3M blue tape but that ain't gonna really stop a sharp piece of gravel.
TIA. :cool:
1990C4S 07-12-2017 08:54 AM
I would consider 3M Vinyl tape. 2" wide. 471 or 764, available 2" wide, easy removal.
onewhippedpuppy 07-12-2017 08:55 AM
I'm not a motorcycle guy, I assume there's no conventional bra type products for a bike?
GH85Carrera 07-12-2017 09:18 AM
One of my friends drives his 1985 911 to Porsche Parade down from Anchorage Alaska. He just covers the front of the car with blue 3M masking tape. It is designed to come off cleanly with no residue. It last for several thousand mile road trips through rain and sleet no problem. He peels it of at Parade, washes his car and it looks fine. Tape it up and head for home a week later.
speeder 07-12-2017 09:40 AM
Thanks. Tape is certainly an option but it would take some time and that stuff is not cheap. Blue tape in wide size is $12-15 a roll. I was thinking some plastic sheet w adhesive where maybe on roll could cover more than one application.
My friend has a GT3 that is covered in Clearbra back to the doors. Amazing stuff but not cheap and I don't think it wants to come off. :)
Nickshu 07-12-2017 09:46 AM
http://i165.photobucket.com/albums/u...gs/Tapejob.jpg
Or this:
http://image.superstreetonline.com/f...nters_tape.jpg
Cooper911SC 07-12-2017 09:52 AM
I install clear bras for a living...
You will do best to get a product like Track Wrap from XPEL. You should install several layers over each other to gain more protection.
Clear bra PPF is around 8 to 9 mils thick. This gives enough protection to stop damage from most small debris penetration.
The Track Wrap, 3M blue masking tape, and vinyl graphics type films run around 2 mils in thickness. Not enough to protect from penetration. They will help with bug guts though.
Good luck with the new bike pick up!
Cooper
speeder 07-12-2017 10:21 AM
Thanks, Cooper! Clear bra is an amazing product and I may consider having it done as a permanent thing but I need a quick solution that I can do in a Lowes parking lot for now.
Do you know where I can buy that other stuff retail?
speeder 07-12-2017 10:30 AM
Ok, I googled it and tracwrap is actually 8 mil thick and only available on their site. Fairly expensive but looks like a great product.
Cooper911SC 07-12-2017 11:08 AM
Glad you got it!
The other "poor mans" route is to go to target, Walmart etc and pick up a roll of opaque shelf and drawer liner.
This is adhesive backed with a low tack adhesive. Many auto cross guys use this rather than the blue tape. Goes on faster and isn't blue...
Should definitely layer though.
C
RANDY P 07-12-2017 11:11 AM
just use ebay 3M bra. When you pull it, sit in the sun, and don't pull away from the adhesive- act like you're straightening a bedsheet- pull it towards you. It pulls off clean.
I do it all the time.
rjp
jyl 07-12-2017 11:51 AM
Disappointing to click on this thread and see what it is actually about. I expected better of the OP.
matthewb0051 07-12-2017 12:05 PM
Yep. I got pulled in by the word "bra". Very disappointing.
scottmandue 07-12-2017 12:06 PM
Here here!
matthewb0051 07-12-2017 12:10 PM
http://forums.pelicanparts.com/uploa...1499886615.png
Tobra 07-12-2017 08:56 PM
How about painters tape so it would come off easily, covered with microfoam tape to give it some padding
speeder 07-12-2017 09:23 PM
Painter's tape is better than nothing but won't really stop a piece of gravel hitting @ 70 mph. I'm liking the drawer liner idea. :)
look 171 07-12-2017 11:00 PM
Denis, here's what we use to protect our newly installed thresholds on all of construction projects and it has worked out really well and simple to install.
We use the painter's blue tape as a base layer, a couple layers of duct tape on top of that. This way the easy release blue tape wouldn't leave you a mess to clean up and the duct tape is tough stuff. In your situation, you may apply 3-4 layers to fend off the gravels. Over the years, its has kept our wood threshold spotless from my men's dirty construction boots and all kinds of dirty and rough stuff.
pksystems 07-13-2017 12:11 AM
Gloss clear plasti-dip or Elastiwrap?
WPOZZZ 07-13-2017 01:12 AM
Helicopter tape. Good, but expensive.
motion 07-13-2017 06:42 AM
I buy clear wrap by the sq ft on ebay and cut it to suit my various bikes. I live on a gravel road, so put a bit on each bike behind the front tire.
Laneco 07-13-2017 08:41 AM
The clear plasti-coat works well.
We use 2" wide heavy grade electrical tape. It peels off pretty clean, a little wipe with an adhesive remover takes care of the residue. It's thick and really does a decent job protecting the paint.
The only disadvantage is that the adhesive goes a little soft in the heat. So if you leave it parked in the sun in the summer, it might lose adhesion.
angela
Mark Henry 07-13-2017 02:43 PM
^ this
Clear plasti dip, trick is several coats and make it thick, then it peels off easy in one piece.
https://www.youtube.com/watch?v=NNurBZVAbWI
David McLaughlin 07-14-2017 10:29 AM
Xpel! The shop I was at wrapped a lot of cars with this. Usually just the standard front but also whole cars. The stuff is heat activated so it self heals. You can even buff it.
jyl 07-15-2017 09:47 PM
Originally Posted by scottmandue (Post 9659707)
Here here!
Must I do everything. Sheesh you'd think this forum is about cars or something.
http://forums.pelicanparts.com/uploa...1500180477.JPG
