Cars & Coffee Killer
legion's Avatar
Triple Post Un-Ignore
And I'm not sorry.
5 liters of VVT fury now
-Chris
Old 07-23-2017, 01:49 PM
DanielDudley's Avatar
CIS components degrade with age. The degradation is caused not so much by age as it is by contaminants and corrosion (which introduces contaminants). The non-Lambda fuel distributor is purely a mechanical device so the degradation slowly occludes the tiny passages causing issue. The WUR is both mechanical and electrical and can suffer from the same occlusions as well as electrical component degradation. At some point the system degrades to the point where fuel pressures and volumes reach levels that are close to being out of spec. That is where you first see issues. At that point I would clean everything. Change the filter, pull the lines, flush and clean everything including the fuel tank. Maintenance buys you time. Once the system is out of spec the components need to be rebuilt and, of course, everything must be flushed and cleaned. I am not a proponent of adjusting the WUR to compensate for a problem - fix the problem.
The vast majority of CIS issues we see could be prevented or at least offset by cleaning and maintenance. Keep the filter changed, inspect and clean the WUR screen, replace old dirty injectors with new, and drop the fuel tank for a full clean out. How often this needs to be done depends on how often the car is driven. The less you drive the car the more frequently you need to maintain the fuel system as it sits and rusts while the water separated out of the gasoline...
...rebuilds for a lot of FDs and WURs, it is unbelievable the shape some are in and the car still runs.
Old 07-23-2017, 03:24 PM
Almost Banned Once
sc_rufctr's Avatar
- Peter
Old 07-23-2017, 05:17 PM
craigster59's Avatar
Why are women like pianos?
Because when they're not....
They're....
Old 07-23-2017, 08:19 PM
Originally Posted by legion View Post
And I'm not sorry.
Old 07-23-2017, 08:27 PM
Run smooth, run fast
Heel n Toe's Avatar
- John
Old 07-23-2017, 11:25 PM
Almost Banned Once
sc_rufctr's Avatar
Thanks John.... Cool song
- Peter
Old 07-23-2017, 11:50 PM
Almost Banned Once
sc_rufctr's Avatar
Do you remember the Opera scene from the 5th Element?
- Peter
Old 07-23-2017, 11:52 PM
Bill is Dead.
cashflyer's Avatar
Chickens
[1] Chicken. Chicken chicken chicken chicken chicken chicken.
Chicken, 10(3):307–314, 2000.
[2] Chicken Chicken. Chicken chicken chicken chicken. Chicken
Chicken Chicken, 12(7):629–639, 1990.
[3] Chicken Chicken. Chicken: Chicken chicken chicken. C. Chicken
Chicken, 32(35):7164–7169, 1993.
[4] C. Chicken chicken Chicken Chicken. Chicken chicken chicken.
Chicken Chicken Chicken Chicken, 4(12):67–74, 1995.
[5] Chicken chicken Chicken Chicken. Chicken chicken chicken.
Chicken Chicken Chicken Chicken, 15(1):542–546, 1990.
Old 07-24-2017, 05:19 AM
