-   -   need help with web page (http://forums.pelicanparts.com/off-topic-discussions/964399-need-help-web-page.html)
rattlsnak 07-25-2017 04:15 PM
Hey, I need some help with a webpage i am updating.. I have some DIVs setup with two columns and when I check everything in a code editor, it displays just fine, but when I upload it to the server, it cuts off the bottom two paragraphs from the right DIV. I have the two DIVs floated left and right inside a parent DIV. I have tried several things, but i cant get it to display those bottom two paragraphs for some reason. I have tried it in several browsers also. I can email the code for you to check it out if you can help.. Help!
Thanks,
Marc
HardDrive 07-25-2017 07:32 PM
PM sent. I spelled your name with a K, my apologies.
HardDrive 07-25-2017 07:33 PM
btw, if the page is live somewhere, you can just send me the link.
RKDinOKC 07-25-2017 07:56 PM
Without seeing anything float them both the same direction and use margin to space them apart.
stomachmonkey 07-25-2017 07:59 PM
Have you cleared the floats?
A good read
https://css-tricks.com/all-about-floats/
rattlsnak 07-25-2017 10:19 PM
Thanks Josh, I sent it to you, and yes, I have tried clearing floats, etc. I'm sure I'm overlooking something tiny!!
RKDinOKC 07-25-2017 10:55 PM
make sure you don't have overflow hidden set. or a specific height set on the parent container.
rattlsnak 07-26-2017 07:58 AM
I have tried it with and without a parent container and with the overflow set to visible, it doesn't work either way.
rattlsnak 07-26-2017 02:53 PM
I just floated them both to the left with @ 25px padding between them and it worked fine. Could not get it to work any other way.. Weird.
HardDrive 07-26-2017 03:53 PM
I just went to the page and it worked fine. I was about to write to you and ask for some clarification on the problem. :D
HardDrive 07-26-2017 03:55 PM
Have you considered simply picking up a free template? You can get something that will look at lot more fresh, and all you have to do is plug in your content.
rattlsnak 07-26-2017 04:34 PM
If you still have the old code, look at it and see why it wouldnt work that way..
And It still has a bunch of art work to be uploaded. It matches the home page.
