2006 GMC Sierra 1500 Door Latch Actuator
My dad owns a 2006 GMC Sierra 1500 truck, crew cab. The front driver's side door will not lock because the yellow plastic piece below is broken. The yellow rod's circular shaped end that holds the door locking rod in place has broken tabs and will not retain the rod in the hole. I cannot use JB Weld or anything like that because the rod has to rotate and pivot in the hole. Any ideas? I cannot find this part on the net. To replace the assembly, it is near $150. All that it needs is the yellow bar.
Thanks in advance, David ![]()
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
You do not have permissi
You just need a metal rod to replace cheap GM plastic.
I fixed a GM door latch which broke just like that. Dad's Geo Metro. The latch was like $250 or something ridiculous. Coat hanger glued into the hollow white piece? This needs to be strong. Maybe drill a hole a hook it all the way through. Put small greased washers to pancake and protect the pivot arm end. And bend it back again on the other side of the pivot to secure. Last edited by john70t; 08-09-2017 at 09:21 AM.. |
I had a spare sitting here for 2 years from when I replaced my door. I would have given it to you . Fudge, I just cleaned up 2 weeks ago, and tossed it , thinking I would never use it. That's how it goes ...
No left turn un stoned |
Unregistered
If I were you (and your glad I'm not) I'd be hitting the pick-a-part places or checking e-bay for a $50 used assembly:
dorman sells this kit if you just need the ends
Fleabit peanut monkey
[QUOTE=VincentVega;9693764]dorman sells this kit if you just need the ends
These would be sold at autozone, etc. What do you call them?
1981 911SC Targa |
Dorman - Help Door Lock Rod Clip Assortment
Check the 'help' section, similar assortment at most parts stores. |
Yep. Found them at Advance Auto online. Thanks. Should solve OP's issue.
1981 911SC Targa |
Thanks for all the replies. I searched for hours for that specific rod. On the looped end, the tabs were broken so it would not retain the rod. The other end has two metal contact points that control the dome light when the door was open.
My dad found a local body shop that had an old one that did not work. He gave the needed piece and installed it for $80. All is well because getting to that particular piece is a pain in the butt. Thanks all!
