-   -   Coolant question (http://forums.pelicanparts.com/off-topic-discussions/966451-coolant-question.html)
Bob Kontak 08-15-2017 02:29 PM
Originally Posted by VincentVega (Post 9701199)
Fill it up and pressurize, you'll see where its leaking if its external.
Nail the problem source, as mentioned.
Change the thermostat. It can stick closed and overheat, venting coolant. Even if ok, I would change for general PM reasons.
Also find if there is an air bleed port.
Clogged radiator
Packed fins
Thermostat
Water pump
Leak
Not much left unless some cam/crank sensor/timing issue and that would spit a code.
