| Registered Join Date: Nov 2005 Location: CA
				Is 2 parts epoxy toxic?
			The gut of my bathroom sink had small pits, very small. I used 2 parts epoxy to fill them up then sanded them smooth, but then stopped for a second thinking this water goes into our mouth every morning. Do you guys think it's ok or should it be replaced?
				__________________ Fat butt 911, 1987 | ||
|  08-09-2017, 09:15 AM |
| Registered Join Date: Nov 2000 Location: AZ
			Stop drinking water out of your bathroom sink and you'll be fine.   Seriously, I'm not seeing how one gets water in their mouth that has previously been "exposed" to the epoxy in the bottom of a sink, but regardless I don't see cured epoxy as being a health risk. The dust you may have potential inhaled during the sanding was probably more harmful. YMMV, not a doctor, yadda, yadda, yadda.   Last edited by Eric Coffey; 08-09-2017 at 10:19 AM.. | ||
|  08-09-2017, 10:12 AM |
| Bill is Dead. Join Date: Jul 2005 Location: Alaska.
			Any worse than drinking from a garden hose?
				__________________ -.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. | ||
|  08-09-2017, 10:20 AM |
| Registered Join Date: Dec 2001 Location: Ky, USA
				 | Quote:
|  08-09-2017, 10:36 AM |
| Unregistered Join Date: Aug 2000 Location: a wretched hive of scum and villainy
			That's how they invented cheeeze!     | ||
|  08-09-2017, 10:42 AM |
| weekend wOrrier Join Date: May 2011
|  08-09-2017, 10:48 AM |
| Registered Join Date: Sep 2009 Location: North of You
			I would not worry about cured epoxy, and certainly not after I had run the water briefly.
				__________________ "A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." | ||
|  08-09-2017, 10:49 AM |
| Cars & Coffee Killer Join Date: Sep 2004 Location: State of Failure
			https://en.wikipedia.org/wiki/Epoxy Quote:
				__________________ Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." | ||
|  08-09-2017, 10:56 AM |
				 |  sorry guys, I meant the core/gut of the faucet on bathroom sink, not the sink itself. And when I said the water goes into our mouth, I meant when we brush our teeth, not drinking this water. Sorry that I wasn't clear.
				__________________ Fat butt 911, 1987 Last edited by rnln; 08-09-2017 at 11:16 AM.. | ||
|  08-09-2017, 11:13 AM |
| Registered |
			A picture would be helpful. Generally, Bondo ( or other similar epoxy based filler), is not waterproof. It requires topcoating. If you are wondering if epoxy, in general, is safe for potable water containers? That is the typical interior lining of most water treatment ponds, piping and storage tanks. You most likely have been drinking out of epoxy your whole life.
				__________________ Randy '87 911 Targa '17 Macan GTS | ||
|  08-09-2017, 11:27 AM |
			My water pipes run under the slab and several years ago they started developing leaks. Options were to run new pipes in attic, or have epoxy coating blown into the pipes.  So obviously at least ONE type of epoxy is safe for drinking water. | ||
|  08-09-2017, 12:14 PM |
| Make Bruins Great Again |
			Some epoxy types leach dangerous chemicals into the water.  Others don't.  For instance, dentists use epoxy that cures with exposure to light.  Find the kind that is safe.
				__________________ -------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera | ||
|  08-09-2017, 03:51 PM |
				 | Quote:
|  08-10-2017, 09:53 AM |
| beancounter Join Date: Jan 2008 Location: Weehawken, NJ
			I lost my front teeth at age 8 in a car accident.  The false replacements are bonded with epoxy, so I have the stuff in my mouth 24/7 for almost 30 years...hope its not toxic    | ||
|  08-10-2017, 11:01 AM |
| Registered Join Date: Jul 2008 Location: New Jersey
			Epoxy is toxic in it's liquid form. Usually associated with epoxy sensitivity which is a sort of rash itch. Once you have epoxy sensitivity it will be irritated when ever you use it. The sensitivity comes from skin contact while the epoxy is still wet. I get it all the time. Very irritating lasts a few days. Wear your gloves to keep it off your hands or for big jobs Tyvek suit. | ||
|  08-10-2017, 04:46 PM |
			I think it's should be similar function of the spindle in the picture
|  09-15-2017, 01:54 PM |
| Air Medal or two Join Date: Jul 2003 Location: cross roads
			like said , once cured (kicked ) and Amine Blush washed off it is pretty much inert according to "system 3"
|  09-16-2017, 12:02 PM |
