-   -   12 volt input computer power supply (http://forums.pelicanparts.com/off-topic-discussions/973560-12-volt-input-computer-power-supply.html)
GH85Carrera 10-11-2017 08:58 AM
I may be looking for something that does not exist, but I can't imagine I am the only one that wants one.
I want to build a computer that runs on a 12 volt power source. I am looking for a way to build a small box powerful computer that runs Win 10 Professional. The software I need to run requires Win 10. It will be a i7 8700 CPU and lots of RAM and a SSD.
It just seems crazy to uses a conventional power supply that is 110 volts, and a power inverter to take the 12 volts system up to 110, just to convert it back to 12 volts.
Who makes a power supply that has the connections to run a ATX motherboard with a SSD drive?
Any suggestions?
aschen 10-11-2017 09:13 AM
SO you have 12v nominal and you need 12v regulated for the computer? DO you need any other voltages like 5 v?
There are plenty of "dc-dc converter" modules that will do this on the cheap. a 12v nominal batt should be consistently over 12v so a simple linear regulator could work as well. How much current/power do you need.
widebody911 10-11-2017 09:17 AM
Why not just get a high-end laptop and a an automotive adapter?
GH85Carrera 10-11-2017 09:23 AM
To answer both questions, yes, we have a 12 volts power supply like a car system.
A high end laptop is expensive, and still does not avoid the issue of 12 volts up to 110 then back to 12. And yea, I need the 5 volts. I want to connect it to a ATX computer motherboard.
I can build a custom computer a LOT cheaper than a high end laptop, and if I need to upgrade or add to it, that is easy. A laptop does nothing except make it hard to configure, and spend a lot of cash.
stomachmonkey 10-11-2017 09:31 AM
Exactly.
You really want to wire all the PC's internal components that are normally feed direct from the PSU to another PSU?
Hide something like this under the seat and be done with it.
http://i.ebayimg.com/images/g/aYQAAO...8r/s-l1600.jpg
GH85Carrera 10-11-2017 09:37 AM
Yea, that would work, but it sure takes up a lot of room, and once again it goes in circles of 12 to 110 to 12 volts.
I want to put it in a non conventional area. I can get a ATX motherboard, a CPU and memory anywhere. Fairly cheap. Why go through multiple transformers changing the voltage?
john70t 10-11-2017 10:16 AM
Do motherboards run on 12v?
If so, just bypass the PSU and make direct connections I'd guess, with surge filter.
Don't some components run on 5v instead?
You'd still need a step-down box to run power wires to those.
stomachmonkey 10-11-2017 10:24 AM
Yes and no.
ATX standard pin out from PSU to MB.
There is, IMHO, no benefit to eliminating the 12V->110->12V cycle.
Lotta work for I'm not sure why.
http://cdn.overclock.net/d/d8/d841da87_ATX20Pinout.jpeg
T77911S 10-11-2017 10:25 AM
you don't need to build the computer, you just need to build the power supply.
the computer is already done.
GH85Carrera 10-11-2017 10:40 AM
I don't want to have to play electrical engineer. I just figured someone already made a computer power supply with a 12 volt input that replaced a conventional power supply with a 110 volt input. Yea, it is easy to just get a power inverter and just plug in a conventional power supply. I just assumed someone made a computer power supply designed to have a 12 volt input to avoid all the conversions. Why waste all that power heating up multiple transformers?
stomachmonkey 10-11-2017 10:42 AM
DC-DC ATX PSUs
GH85Carrera 10-11-2017 10:59 AM
Originally Posted by stomachmonkey (Post 9772163)
COOL!
I will see what systems they have. May well get an entire computer setup from them. Now I gotta go shopping!
Thanks!
