The Original STAINLESS STEEL Meat Grinder Attachment for Kitchenaid Mixer PLUS Sausage Stuffing Kit - Smokehouse Chef It's a bit small, but it's probably all the Kitchen Aid motor can stand, plus, being all stainless, you can do anything to - heat, chemicals, autoclave - it to sterilize it. |
Lots of good cooks on this thread. Indeed, you want a "cheap" cut of meat. It has more flavor. Higher on the animal will be more tender but definitely not more flavorful.
I would change exactly zero on your recipe. Not even the grind. What if it doesn't have the same mouth feel? I make a classic chili where you cube the meat and cook it long enough to where it falls apart into shreds. The recipe calls for cheap cuts of meat as well. I read that this is how it used to be when they dehydrated it into blocks that you could take on the trail, add water - instant chili. You guys should explore this some time! G |
Yep, chunks/cubes of Chuck Roast is where it's at. Ground turkey is also a good alternative for a healthier option. I am in the "beans" camp though, so I prefer to call it "bean soup" as to not offend the Chili purists, lol.
I'll add a couple cans of beans (2 Kidney, 1 Pinto, 1 Black, and 1 Garbanzo), draining them and replacing the liquid with a couple Guinness beers. I don't like diced/chunky tomoatos though, so I just stick with a good tomato sauce. Then of course a good mix of chili seasoning, garlic, onions, (can do a rue first), and dice jalapenos goes in. Maybe a little cocoa powder too. I'll usually let a big pot simmer for a few hours. If you want to kick it up a notch, you can slip in a few Carolina Reapers, lol... Serve with sour cream, shredded cheddar, and Fritos! |
Some good advice here. This weekend would be a good time for some chili. I've got a LOT of garden tomatoes to eat. |
Turkey makes me want gobble, gobble. Now a bit of cocoa powder...ummmm that's interesting. Mike. I use dried beans. |
For me, not everything has to be a Michelin Star culinary masterpiece, and the above is a good quick-n-dirty compromise for those (like me) that don't have the time to bother with soaking beans, etc. That said, I didn't reveal all my secrets, and I am betting you would scarf it up just fine with no complaints. ;) Make the trek down here to PHX with some of your Q, and I'll make you a pot. |
Best chilli I ever made used pulled smoked chuck roast.
Never done coffee though... |
I'm a novice compared to some of y'all...got some ideas from this thread too :). I do the big ol' crockpot, 8 hour method...couple of lbs ground and cubed, peppers, spices, diced 'maters, beans....never comes out the same way...sometimes a bit too hot :), but always good. My long time buddy might kill me for giving away "his" secret....a pinch, and I really mean a pinch....of cinnimon...
What we need is a PPOT chili and Q off competition....I won't win but volunteer my services as a judge :)
But as you mention, it only takes a very tiny amount, and most over-do it. If you can actually taste cinnamon, then you f'd it up. |
I am definately NOT a chili purist. I like my black beans, and white cannalini beans, along with a diced tomatoes. I use whole hog sausage, and sometimes a strip steak cut into cubes. Green Tabasco tops it off with just a pinch of brown sugar, and served with corn bread.....let the internet flaming start !
Many times while camping, this is fixed over an open campfire in cast iron, while the cornbread is baked in a cast dutch oven. |
The turkey frozen in an economy tube is course and chunky. Fresh ground turkey can vary in texture, but typically more tender than the frozen stuff. I recently used some turkey in frozen burger patty shapes, it was the finest ground yet (almost no texture) and had good flavor too. EDIT: If you have a recipe you are happy with, don't change it for the competition. Experiment after the competition. |
Interesting read on the "history" of chili:
1850 – Records were found by Everrette DeGolyer (1886-1956), a Dallas millionaire and a lover of chili, indicating that the first chili mix was concocted around 1850 by Texan adventurers and cowboys as a staple for hard times when traveling to and in the California gold fields and around Texas. Needing hot grub, the trail cooks came up with a sort of stew. They pounded dried beef, fat, pepper, salt, and the chile peppers together into stackable rectangles which could be easily rehydrated with boiling water. This amounted to “brick chili” or “chili bricks” that could be boiled in pots along the trail. DeGolyer said that chili should be called “chili a la Americano” because the term chili is generic in Mexico and simply means a hot pepper. He believed that chili con carne began as the “pemmican of the Southwest.” https://whatscookingamerica.net/History/Chili/ChiliHistory.htm |
Used leftover brisket, smoked the day before, just last weekend...first time I tried it. Turned out really nice and had a big beefy flavor.
| All times are GMT -8. The time now is 12:25 PM. |
